Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Simscale and Fusion 360 (latest versions)
1 REPLY 1
dstokes2XX9Y
169 Views, 1 Reply
I have read that the Simscale add-in is still available, and I have downloaded and attempted to install the pkg. However, I don't see the add-in available anywhere in Fusion 360, even though the add-in says it is successfully installed. I have previously used Simscale after exporting models from Fusion 360 and would appreciate the more streamlined workflow of having the link available directly within Fusion.  Is this no longer available in version 2.0.8156?
1 REPLY 1
OceanHydroAU
in reply to: dstokes2XX9Y
You might need to look in the add-in source to find out where it put itself?
That's assuming it did?  Maybe you need to use the "S" shortcut, locate it, then click "Run"?
(also, if it's an add-in, maybe you need to click the "run on startup" box?)
