Announcements
Simple script to show bounding box length, width & thickness
isocam
isocam
Can anybody help?
Can anybody create a simple Python script for me that shows a the length, width & thickness of a part (not an assembly) using the following?
L = component.boundingBox.maxPoint.x - component.boundingBox.minPoint.x
W = component.boundingBox.maxPoint.y - component.boundingBox.minPoint.y
H = component.boundingBox.maxPoint.z - component.boundingBox.minPoint.z
Many thanks in advance!
Darren
kandennti
Hi @isocam .
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui: adsk.core.UserInterface = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.fusion.Application = adsk.core.Application.get()
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        comp: adsk.fusion.Component = des.activeComponent
        bBox: adsk.core.BoundingBox3D = comp.boundingBox
        maxPnt: adsk.core.Point3D = bBox.maxPoint
        minPnt: adsk.core.Point3D = bBox.minPoint
        length = abs(maxPnt.x - minPnt.x)
        width = abs(maxPnt.y - minPnt.y)
        height = abs(maxPnt.z - minPnt.z)
        unitsMgr: adsk.core.UnitsManager = des.unitsManager
        defLenUnit = unitsMgr.defaultLengthUnits
        retio = unitsMgr.convert(1, unitsMgr.internalUnits, defLenUnit)
        msg = [
            f'-- {comp.name} --',
            f'length : {length * retio} {defLenUnit}',
            f'width : {width * retio} {defLenUnit}',
            f'height : {height * retio} {defLenUnit}',
        ui.messageBox('\n'.join(msg))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
BrianEkins
What @kandennti posted is a good solution.  However, anytime you want to display a value to the user I would recommend using the UnitsManager.formatInternalValue method. This will take the value and format it using the settings the user has specified in their preferences.
Brian Ekins
