Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Show "Properties" Dialog Box For Parts & Assemblies
1 REPLY 1
isocam
116 Views, 1 Reply
Can anybody help?
I have the following Fusion 360 "Python" script file....
import adsk.core, adsk.fusion, traceback
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
des = app.activeProduct
root = des.rootComponent
sels = ui.activeSelections
sels.add(root.bRepBodies[0])
app.executeTextCommand(u'Commands.Start FusionPropertiesCommand')
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
It works great when I run the script on a "Part" document but not on a "Assembly" document.
Can anybody update the script for me so that it works on both "Part" & "Assembly" documents?
Many thanks in advance!
Darren
1 REPLY 1
Rushikesh.kadam
in reply to: isocam
@isocam you need to use the component instance under which the body is present. Attached is the modified code. I have assumed the body is present under the first instance of the component. One needs to make sure that the component and body exist before accessing them.
#Author-
#Description-
def run(context):
    ui = None
    try:
        # here use the component instance under which the body is present
        #  for which the properties dialog needs to display.
        sels.add(root.allOccurrences[0].bRepBodies[0])
    except:
        if ui:
If my reply was helpful, please click the "Accept as Solution" button. It helps others get the answer quickly! A "Like" is always welcomed
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
