Show/Hide JointOrigin
jonrbloom
Message 1 of 13
jonrbloom
Is there an equivalent to isLightBulbOn for JointOrigins? I see this for other objects, but JointOrigins appear to be visible by default when created through the API, and there's no obvious way to hide them.
Replies (12)
Message 2 of 13
kandennti
Hi @jonrbloom .
After trying various things, I was able to switch in this way.
#Fusion360API Python script
import adsk.core, adsk.fusion, traceback
_app = adsk.core.Application.cast(None)
_ui = adsk.core.UserInterface.cast(None)
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        des  :adsk.fusion.Design = _app.activeProduct
        root :adsk.fusion.Component = des.rootComponent
        # First JointOrigin
        jointOrigin = root.allJointOrigins[0]
        # Switching Show/Hide
        SwitchingLight(jointOrigin)
        _ui.messageBox('Done')
    except:
        if _ui:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def SwitchingLight(item :adsk.core.Base):
    ui = app.userInterface
    sels = ui.activeSelections
    sels.clear()
    sels.add(item)
    txtCmd = u'Commands.Start VisibilityToggleCmd'
    # txtCmd = u'Commands.Start CAMVisibilityToggleCmdDef' #OK
    # txtCmd = u'Commands.Start ShowHideBodyCmd' #OK
    app.executeTextCommand(txtCmd)
    sels.clear()
However, I didn't know how to judge Show / Hide.
Message 3 of 13
jonrbloom
@kandennti - That's thinking out of the box 🙂 Thank you for taking the time to experiment with this.
Your solution does work, but only if the JointOrigin is obtained from the root component context.
I'm still a newbie with the API. Is there an easy way to convert a JointOrigin (or any of the other objects for that matter) obtained from a sub-component into it's corresponding root context? I can use a brute force search to find it by iterating over the roots allJointOrigins, but am hoping there's a more direct method to do this?
Message 4 of 13
kandennti
Just put JointOrigin in the parameter of the SwitchingLight function and it should work.
However, this is useless because it cannot be determined whether it is displayed or hidden.
Message 5 of 13
MichaelT_123
Hi Fellows,
It seems that the issue is still ringing...
FYI:
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/jointorigin-isvisible/td-p/9306477
Regards
MichaelT
MichaelT
Message 6 of 13
kandennti
Thank you @MichaelT_123 .
There was a problem from the past.
I've tried various things, but I can't find a solution.
Message 7 of 13
jonrbloom
@kandennti  - I did try your example. But it only worked if I obtain the JointOrigin drirectly from the rootComponent. If I create a sub-component, adding a JointOrigin as I go to that sub-component, the created JointOrigin is rejected by the sels.add() call.
It seems I can only add entities obtained from the rootComponent to activeSelections.
Message 8 of 13
jonrbloom
@kandennti  - I should add, that I don't think your solution is useless at all. As it stands my script assumes a blank design, so all JointOrigins are new, and guaranteed to be visible. Even without the per-component toggling, this is far better than leaving lots of ugly warts over the final model.
So thank you for the help 🙂
But it would be nice if this does get fixed eventually, as per @MichaelT_123's thread. Fingers crossed.
Message 9 of 13
kandennti
@jonrbloom .
I didn't understand the proxy.
I referred to the @BrianEkins sample.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/cannot-select-object-in-component-using-ac...
The following sample creates a Box in RootComponent and Occurrence and hides the jointOrigin created at the vertex.
def run(context):
    try:
        global _app, _ui
        # create document
        _app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        # --- try root ---
        # create box
        box = createBox(root, adsk.core.Point3D.create(0.0, 0.0, 0.0))
        # create jointOrigin
        jointOrigins = createJointOriginList(box, root)
        # jointOrigin Hide
        [SwitchingLight_JointOrigin(o) for o in jointOrigins]
        # --- try occurrence ---
        # create occurrence
        matZero = adsk.core.Matrix3D.create()
        occ :adsk.fusion.Occurrence = root.occurrences.addNewComponent(matZero)
        # create box
        box = createBox(occ.component, adsk.core.Point3D.create(20.0, 0.0, 0.0))
        jointOrigins = createJointOriginList(box, occ.component)
        # jointOrigin Hide
        # finish
    except:
        if _ui:
def createJointOriginList(
    box :adsk.fusion.BRepBody,
    comp :adsk.fusion.Component
    ) -> list:
    jointGeo = adsk.fusion.JointGeometry
    jointGeos = [jointGeo.createByPoint(p) for p in box.vertices]
    originIpts = [comp.jointOrigins.createInput(p) for p in jointGeos]
    return [comp.jointOrigins.add(ipt) for ipt in originIpts]
def createBox(
    comp :adsk.fusion.Component,
    pnt :adsk.core.Point3D
    ) -> adsk.fusion.BRepBody:
    vec3D = adsk.core.Vector3D
    lVec = vec3D.create(1.0, 0.0, 0.0)
    wVec= vec3D.create(0.0, 1.0, 0.0)
    bouBox3D = adsk.core.OrientedBoundingBox3D
    box = bouBox3D.create(pnt, lVec, wVec, 10, 10, 10)
    tmpBrMgr = adsk.fusion.TemporaryBRepManager.get()
    baseFeats = comp.features.baseFeatures
    baseFeat = baseFeats.add()
    baseFeat.startEdit()
    cube :adsk.fusion.BRepBody = comp.bRepBodies.add(tmpBrMgr.createBox(box),baseFeat)
    baseFeat.finishEdit()
    return cube
# Switching Show/Hide JointOrigin
def SwitchingLight_JointOrigin(
    jointOrigin :adsk.fusion.JointOrigin):
    app :adsk.core.Application = adsk.core.Application.get()
    ui :adsk.core.UserInterface = app.userInterface
    des :adsk.fusion.Design = app.activeProduct
    comp :adsk.fusion.Component = jointOrigin.parentComponent
    sels :adsk.core.Selections = ui.activeSelections
    sels.clear()
    occs :adsk.fusion.OccurrenceList = root.allOccurrencesByComponent(comp)
    if occs.count < 1:
        # root
        sels.add(jointOrigin)
    else:
        # occ
        proxy :adsk.fusion.JointOrigin = jointOrigin.createForAssemblyContext(occs[0])
        sels.add(proxy)
    sels.clear()
Pass the new JointOrigin to the SwitchingLight_JointOrigin function and it should be hidden.
Message 10 of 13
jonrbloom
This works, and helped me understand the proxy concept better too. Thanks.
Message 11 of 13
MichaelT_123
Hi Fellows,
Just to let you know.
jointOrigin.isVisible = True/False
works!
Regards
MichaelT
MichaelT
Message 12 of 13
jonrbloom
It looks like isVisible is intended to be read-only. And recent changes are locking that down to return an error for such properties. If it is still working today I would be wary of relying on this.
@MichaelT_123 wrote:
Hi Fellows,
works!
Regards
MichaelT
Message 13 of 13
MichaelT_123
Hi Mr JonRBloom,
As per this thread and perhaps other posts related to the issue, the problem one would consider quite simple is not new.
I don't know how you are familiar with API and its development (or changes) over the years.
Let's look at this particular trivial case of visibility of an icon marking visibility of browser members (including jointOrigin).
If you study API documentation, you will find that this property can be set or/and get using two properties isVisible and isLightBulbOn. On top, there are also (added not long time ago group properties like for example isJointsFolderLightBulbOn.
It seems that during the software development life, there were two competing parties in not necessarily well-synchronized teams.
One party I would call Visi_Cratic and other GE_Cratic (short for LightBulbOn_Cratic).
There was also the vicious battle about the colour of the respective icon.
isVisible parameter is sometime settable & gettable and, on other occasions, only gettable. It is hard to devise the pattern here (perhaps the research of the phenomena could lead to a high degree in Methods Of Software Development Department at Esteemed University)
 isLightBulbOn seems to be set/get/able.
So about your concern: 'If it is still working today, I would be wary of relying on this.'
I agree I can't predict the outcome when I pick my nose. Predicting what will happen when F360 digs into the problem is much, much harder, perhaps impossible.
Regards
MichaelT
PS.
As jointOrigin.isVisible = True/False seems to work now, it is still not documented. (checked couple days ago)
MichaelT
