Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Set Plane By Distance On Path
5 REPLIES 5
barbaracc6
323 Views, 5 Replies
Hello guys,
In one of my models I needed to use the command setByDistanceOnPath to create a plane at various distances from the path. The path is shown on the second picture.
I noticed that, doing the procedure manually, everything goes well (second picture) and the plans are created where I want (proportions:
0.05, 0.1, 0.15, 0.2, 0.25, 0.3, 0.35, 0.4, 0.45, 0.5, 0.55, 0.6, 0.65, 0.7, 0.75, 0.8, 0.85, 0.9, 0.95).
However, when I try to do the same procedure via API, the plans are created in a section or distance that does not correspond to the intended one.
I'll leave the step model below and the code I've done so far. I also leave images of how the plans are being created via API vs via visual interface.
Need urgent help on this matter...
I appreciate any help initiative!
CODE:
Labels (2)
5 REPLIES 5
barbaracc6
in reply to: barbaracc6
CODE:
import
adsk.core, adsk.fusion, traceback
import os.path
from decimal import Decimal
import math
def run(context😞
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        ################################## IMPORT THE CREATED STP FILE #####################################
        # Access the import manager and root component
        importManager = app.importManager
        rootComp = app.activeProduct.rootComponent
        # Get a Pop-Up window to appear and ask the user to select the STEP file
        fileDlg = ui.createFileDialog()
        fileDlg.isMultiSelectEnabled = False
        fileDlg.title = 'Open STEP File'
        fileDlg.filter = 'STEP files (*.ste;*.step;*stp)'
        # Get the STEP file open
        msg = ''
        dlgResult = fileDlg.showOpen()
        if dlgResult == adsk.core.DialogResults.DialogOK:
            msg += '\nFiles to Open:'
            for filename in fileDlg.filenames:
                msg += '\n\t{}'.format(filename)
        else:
            return
        # Create the input options and import them to the target
        importOptions = importManager.createSTEPImportOptions(filename)
        importManager.importToNewDocument(importOptions)
        ######################################### FIND EDGE OF THE PATH #########################################
        design = adsk.fusion.Design.cast(app.activeProduct)
        rootC = design.rootComponent
        bodies = rootC.bRepBodies
        #Define the body
        Body1 = bodies.item (0)
        Edges_Body1 = Body1.edges
        NrEdges_Body1 = Body1.edges.count
        Edge_Path = None
        for i in range (0, NrEdges_Body1):
            Edge_Body = Edges_Body1.item(i)
            StartEdge_x_Body1 = Edge_Body.startVertex.geometry.x
            StartEdge_x_Body1 = abs(StartEdge_x_Body1)
            StartEdge_x_Body1 = round (StartEdge_x_Body1, 1)
            EndEdge_x_Body1 = Edge_Body.endVertex.geometry.x
            EndEdge_x_Body1 = abs (EndEdge_x_Body1)
            EndEdge_x_Body1 = round(EndEdge_x_Body1, 1)
            if StartEdge_x_Body1==0 and EndEdge_x_Body1==36.6 or EndEdge_x_Body1==0 and StartEdge_x_Body1==36.6 and Edge_Path==None:
                Edge_Path = Edges_Body1.item(i)
                #ui.messageBox ('Edge index: {}'.format(i))
        ######################################### MAKE PLANES ALONG THE PATH #########################################
                Geodesic_distance = Edge_Path.length
                Geodesic_distance = round (Geodesic_distance,6)
                ui.messageBox ('Geodesic distance: {}'.format(Geodesic_distance))
                # Get construction planes
                planes = rootC.constructionPlanes
                # Create construction plane input
                planeInput = planes.createInput()
                # Add construction plane by distance on path
                proportion = [0.05, 0.1, 0.15, 0.2, 0.25, 0.3, 0.35, 0.4, 0.45, 0.5, 0.55, 0.6, 0.65, 0.7, 0.75, 0.8, 0.85, 0.9, 0.95]
                #app = adsk.core.Application.get()
                #ui = app.userInterface
                #edgeSel = ui.selectEntity('Select edge.', 'Edges')
                #selectedEdge = adsk.fusion.BRepEdge.cast(edgeSel.entity)
                for i in range (0, len(proportion)):
                #distance = adsk.core.ValueInput.createByReal (1.0)
                    distance = adsk.core.ValueInput.createByReal (proportion[i])
                    planeInput.setByDistanceOnPath(Edge_Path, distance)
                #planeInput.setByDistanceOnPath(selectedEdge, distance)
                    planes.add(planeInput)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
@barbaracc6 This looks to be a bug in API for a non-native (other than .f3d/.f3z) Fusion file. Unfortunately, I am not able to find a workaround. I tried the code on a similar .f3d file and it worked but was able to reproduce the case after exporting the same file as a .step and using it. Any chance you have the original file in .f3d format? It should work on it.
I have reported the case to the API team for future analysis. Thank you for reporting it.
If my reply was helpful, please click the "Accept as Solution" button. It helps others get the answer quickly! A "Like" is always welcomed
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
@Rushikesh.kadam thank you for the answer. Unfortunately, i do not have the .f3d or .f3z file, only the .STEP one. Do you know if this bug will be solved shortly? Is there any other way to do what i am trying to do?
@barbaracc6 After some deep analysis found out that the issue is observed only when the design type is Direct modeling. After import of the file if I changed the design type to Parametric modeling using
design.designType = 1 , the planes are generated correctly. Below is the modified code. I also took the liberty to remove some lines of code that were redundant.
import adsk.core, adsk.fusion, traceback
import os.path
import math
def run(context):
    ui = None
    try:
        msg = ''
        else:
            return
        # Change the design type to Paramteric
        #Define the body
        Edge_Path = None
    except:
        if ui:
 For the issue observed when the design type is direct modeling (the original issue reported in this post) a bug is reported.
Hope this helps.
If my reply was helpful, please click the "Accept as Solution" button. It helps others get the answer quickly! A "Like" is always welcomed.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
Can't thank you enough for all the help provided in such a quick time!
Keep up with the good job!
Technology Administrators
