I'm looking for a solution where I can limit the input range of values. My goal is to rule out negative numbers and numbers higher than a set limit. For example: input is valid when between 10 and 100. Let's say someone tries 1000, it's not valid and an errormessage is displayed.
My ideas of doing this:
In the CommandValidateInputsHandler, but I can test on (e.g.) toplimit but not the lower limit at the same time.
Second idea: this must be done in the creation of the input as a isValidExpression.
What I've tried, but not seems to be working..
# Event handler for the validateInputs event. class SampleCommandValidateInputsHandler(adsk.core.ValidateInputsEventHandler): def __init__(self): super().__init__() def notify(self, args): try: app = adsk.core.Application.get() ui = app.userInterface eventArgs = adsk.core.ValidateInputsEventArgs.cast(args) inputs = eventArgs.firingEvent.sender.commandInputs # Verify . scaleInput = inputs.itemById('scale') if 10 < scaleInput.value < 100 : eventArgs.areInputsValid = True else: scaleInput = inputs.itemById('value') if 10 < scaleInput.value < 100 : eventArgs.areInputsValid = True else: eventArgs.areInputsValid = False except: if ui: ui.messageBox('Failed ValidateInputsHandler:\n{}'.format(traceback.format_exc()))
Could you point me in the right direction?
Hi Mr. TheArterzt,
Consider :
class SampleCommandChangedInputsHandler(adsk.core.InputChangedEventHandler):
bla, bla bla,...
if scaleInput.value < 10 : scaleInput.value = 10
bla, bla bla
Regards
MichaelT
