Serial module not supported by AddIns on Python?
vgegok
vgegok
I created an add-on module to receive posture angles from serial devices (Arduino+MPU6050), but when I added serial-related code to the project, there was no response when I executed the add-on module.
I don't know where to see the error message.
Is serial not supported by add-on modules?
My AddIns code is as follows:
# Assuming you have not changed the general structure of the template no modification is needed in this file.
import adsk.core
import adsk.fusion
import adsk.cam
import traceback
import threading
import random
import json
import serial
handlers = []
class ThreadEventHandler(adsk.core.CustomEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            # Make sure a command isn't running before changes are made.
            if ui.activeCommand != 'SelectCommand':
                ui.commandDefinitions.itemById('SelectCommand').execute()
            eventArgs = json.loads(args.additionalInfo)
            newEye = adsk.core.Point3D.create(float(eventArgs['Roll']), float(eventArgs['Pitch']), 1)
            # newEye = adsk.core.Point3D.create(float(eventArgs['Value']), 0, 1)
            camera.eye = newEye
            app.activeViewport.camera = camera
            # app.activeViewport.fit()
        except:
            if ui:
                ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class CaptureCamThread(threading.Thread):
    def __init__(self, event):
        threading.Thread.__init__(self)
        self.stopped = event
    def run(self):
        try:
            ser = serial.Serial('COM4', 115200, timeout=1)
            while not self.stopped.wait(2):
                # while(True):
                read = ser.readline()
                read = read.decode()
                if read != '':
                    RollPitch = read.split()
                    # print(type(RollPitch))
                    Roll = float(RollPitch[0])
                    Pitch = float(RollPitch[1])
                    args = {'Roll': Roll, 'Pitch': Pitch}
                    app.fireCustomEvent('CaptureCamThreadID', json.dumps(args))
        except:
            if ui:
def run(context):
    global app
    global ui
    global view
    global camera
    global eye
    try:
        # This will run the start function in each of your commands as defined in commands/__init__.py
        app = adsk.core.Application.get()
        ui = app.userInterface
        view = app.activeViewport
        camera = view.camera
        eye = camera.eye
        global customEvent
        customEvent = app.registerCustomEvent('CaptureCamThreadID')
        onThreadEvent = ThreadEventHandler()
        customEvent.add(onThreadEvent)
        handlers.append(onThreadEvent)
        global stopFlag
        stopFlag = threading.Event()
        myCaptureCamThread = CaptureCamThread(stopFlag)
        myCaptureCamThread.start()
    except:
        if ui:
def stop(context):
    try:
        if handlers.count:
            customEvent.remove(handlers[0])
        stopFlag.set()
        app.unregisterCustomEvent('CaptureCamThreadID')
        ui.messageBox('Stop addin')
    except:
        if ui:
This is a script, Like Addins, I encountered the same problem:
# Author-vgegok
# Description-
import adsk.core
import adsk.fusion
import adsk.cam
import traceback
import serial
import time
def run(context):
    ui = None
    try:
        eye = camera.eye
        for i in range(0, 100):
            # while(True):
            time.delay(2)
            if read != '':
                newEye = adsk.core.Point3D.create(Roll, Pitch, 1)
                camera.eye = newEye
        ui.messageBox(str(eye.x))
    except:
        if ui:
Some examples can be referred?
kandennti
Hi @vgegok .
As with general python, if you want to use external modules, you need to install them.
However, since the Fusion360API python is a proprietary environment, it cannot be installed by a simple pip install.
The installation of "numpy" is a relatively popular topic in the forum, so please search for "numpy".
vgegok
Thank you very much. As you know, I successfully installed pyserial and ran Add INS!
However, I have encountered a new problem. When I use pyserial to continuously receive data from the serial port, Fusion 360 may get stuck or crash.
Here is my code:
import adsk.core
import adsk.fusion
import adsk.cam
import traceback
import threading
import json
import serial
handlers = []
    def __init__(self):
        super().__init__()
        try:
            camera.eye = newEye
        except:
            if ui:
    def run(self):
        try:
            while not self.stopped.wait(1):
                # Roll = 1
                # Pitch = 0
                # args = {'Roll': Roll, 'Pitch': Pitch}
                # app.fireCustomEvent('CaptureCamThreadID', json.dumps(args))
                ser.reset_input_buffer()
                read = ser.readline().decode()
                if len(read) != 0:
                    Roll = abs(float(RollPitch[0]))
                    Pitch = abs(float(RollPitch[1]))
                    # f.close()
        except:
            if ui:
def run(context):
    global app
    global ui
    global view
    global camera
    global eye
    try:
        eye = camera.eye
        global customEvent
        global stopFlag
    except:
        if ui:
def stop(context):
    try:
        if handlers.count:
        stopFlag.set()
        # ui.messageBox('Stop addin')
    except:
        if ui:
Jorge_Jaramillo
Hi @vgegok ,
I believe your blocking Fusion issue is because you are using the ser.readline() in CaptureCamThread.run() method to wait for the input. Since this function blocks the thread, maybe it is not giving enough time to Fusion to run.
I'd suggest use an async function to read from the serial port, which won't cause the thread to be blocked (maybe
await asyncio.wait(...) could be used).
I had used that kind of async functions to make inter-process communication, leaving enough CPU time to Fusion without any performance issue.
Hope this could help.
Jorge Jaramillo
vgegok
Okay, thank you for your reply, I will try according to your ideas!
