Hi @Aaargh74 .
Interesting subject.
At first I thought I could determine self-intersections with the SurfaceEvaluator.getParamAnomaly method, but I could not.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-d6b7d30a-972b-4117-9292-c0a87be8ba62
The next method I came up with was to use the TemporaryBRepManager.createWireFromCurves method.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-62A548C4-305D-47D3-9574-A09743736FC8
I created a sample like this.
Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
ui: adsk.core.UserInterface = None
try:
app: adsk.core.Application = adsk.core.Application.get()
ui = app.userInterface
msg: str = 'Select Face'
selFilter: str = 'Faces'
sel: adsk.core.Selection = selectEnt(msg, selFilter)
if not sel:
return
face: adsk.fusion.BRepFace = sel.entity
if isSelfIntersect(face):
msg = 'Self intersecting.'
else:
msg = 'Not self intersecting.'
ui.messageBox(msg)
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def isSelfIntersect(
face: adsk.fusion.BRepFace) -> bool:
tempMgr: adsk.fusion.TemporaryBRepManager = adsk.fusion.TemporaryBRepManager.get()
curves = [e.geometry for e in face.edges]
try:
tempMgr.createWireFromCurves(
curves,
False
return False
except:
return True
def selectEnt(
msg: str,
filterStr: str) -> adsk.core.Selection:
try:
app = adsk.core.Application.get()
sel = ui.selectEntity(msg, filterStr)
return sel
except:
return None
I tried it with the attached file and it is able to determine.
However, since self-intersections are determined by the boundaries, it could not be determined for shapes where the boundaries are not self-intersecting.
The only other way I can think of is that self-intersecting surfaces will cause offset surfaces to fail, even if they are only a short distance away. However, I did not know if it is possible to determine that a surface with an offset failure is always self-intersecting.
Also, I can't think of any way to remove the unwanted part.
