how can I know the index of a face of a cube? This it what I want to do:
Select a plane- draw a rectangle- extrude it- make new sketch on a specific face of that cube. Automatically, not by user selection. How to find/choose the wanted face?
Here's a link to a paper I presented a couple of years ago at Autodesk University. There's a section called "Accessing Topology Objects" that specifically addresses your question but the rest of it will be useful to help you get a broader view of how it all works.
Hi @oyvindTMNSU .
If it is a simple cube and direction, you can determine it by the center of gravity of the face.
This is not an index, but a sample of finding a BRepFace and creating a sketch text.
Fusion360API Python script
import adsk.core, adsk.fusion, traceback
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
des :adsk.fusion.Design = app.activeProduct
root :adsk.fusion.Component = des.rootComponent
# get body
body :adsk.fusion.BRepBody = root.bRepBodies[0]
# get face
# Judgment by the position of the center of gravity
faces :adsk.fusion.BRepFaces = body.faces
lst =[
['top', max(faces, key=(lambda f: f.centroid.z))],
['bottom', min(faces, key=(lambda f: f.centroid.z))],
['right', max(faces, key=(lambda f: f.centroid.x))],
['left', min(faces, key=(lambda f: f.centroid.x))],
['front', min(faces, key=(lambda f: f.centroid.y))],
['back', max(faces, key=(lambda f: f.centroid.y))]
# create Sketch Text
for name, face in lst:
createText(name, face)
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def createText(
face :adsk.fusion.BRepFace
comp :adsk.fusion.Component = face.body.parentComponent
skt :adsk.fusion.Sketch = comp.sketches.addWithoutEdges(face)
txts :adsk.fusion.SketchTexts = skt.sketchTexts
txts.add(txts.createInput(name, 1, skt.modelToSketchSpace(face.centroid)))
Hi M?. OyvindTMNSU
The face(s) can be determined from the chain of processes leading to their creation.
Let's assume that a cube has been created by extrude feature.
Extruded profile's path segments give you indexes of side faces which can be accessed by extrudeFeat.sideFaces.
Cups of an extrude can be referenced by extrudeFeat.startFaces and extrudeFeat.endFaces.
There are similar schemes available for other methods of face creation.
Regards
MichaelT
Thank you.
It it obvious which of the 4 sides of the box extrude to choose. Like, is it always start counting from left to right or is it some kind of system at all? Meaning, how to differ between the 4 side faces of an extrude of a rectangle?
Hi M?. OyvindTMNSU
The answer is summarized in my previous post-sentence:
''Extruded profile's path segments give you indexes of side faces which can be accessed by extrudeFeat.sideFaces.item(idx).''
In other words, faces will likely correspond to separate line/curve segments constituting the extruded profile. I use word likely here, as based on my diligence it is not clearly stated in API, although the method works in practice. In order to be absolutely sure one can check match between face's edges and profile's segments. It is however, quite expensive.
Regards
MichaelT
Relying on indices is usually risky. Even if it seems to work now it's possible it may not work in the future. I prefer finding faces geometrically. Here are a couple of approaches:
Thanks! I saw someting about that in the link you posted and i will try it!
Thanks!
Would you mind to give me a quick example code doing this?:
Sketching a rectangle on an origin plane -> extrude it --> make a sketch on the end face.
Just to Kickstart me a bit...
Thanks in advance!
Here's a small example that uses the findBRepUsingPoint method to find the face of the box.
def run(context):
try:
des: adsk.fusion.Design = app.activeProduct
root = des.rootComponent
# Crate a sketch on the XY plane and draw a rectangle 10 x 7.
sk = root.sketches.add(root.xYConstructionPlane)
sk.sketchCurves.sketchLines.addTwoPointRectangle(adsk.core.Point3D.create(0,0,0),
adsk.core.Point3D.create(10,7,0))
# Create an extrusion.
prof = sk.profiles.item(0)
boxHeight = adsk.core.ValueInput.createByReal(5)
extrude = root.features.extrudeFeatures.addSimple(prof, boxHeight,
adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
# Get the created body.
body = extrude.bodies.item(0)
# Find one of the side faces.
foundFaces = root.findBRepUsingPoint(adsk.core.Point3D.create(10, 3.5, 2.5),
adsk.fusion.BRepEntityTypes.BRepFaceEntityType)
# If the face was found, create a sketch and draw a rectangle on it.
if foundFaces.count == 1:
sideFace = foundFaces.item(0)
# Create a sketch so the edges of the face aren't copied into the sketch.
sk = root.sketches.addWithoutEdges(sideFace)
# Define the corner points of the sketch in model space.
modelPnt1 = adsk.core.Point3D.create(10, 1, 1)
modelPnt2 = adsk.core.Point3D.create(10, 6, 4)
# Get the equivalent points in sketch space.
skPnt1 = sk.modelToSketchSpace(modelPnt1)
skPnt2 = sk.modelToSketchSpace(modelPnt2)
# Draw the rectangle and extrude it.
sk.sketchCurves.sketchLines.addTwoPointRectangle(skPnt1, skPnt2)
root.features.extrudeFeatures.addSimple(prof, adsk.core.ValueInput.createByReal(2),
adsk.fusion.FeatureOperations.JoinFeatureOperation)
except:
if ui:
Finding the face is the easy part. There are some other things you need to understand once you've found that face to successfully draw the sketch for the next extrusion. Every sketch has its own coordinate system and the geometry you draw in that sketch is with respect to that coordinate system. Creating a sketch on the base XY construction plane is a special case where the sketch coordinate system and the model coordinate system line up with one another. If you create a sketch on the other base construction planes, their origins will align with the model origin but the orientations will be different.
When creating a sketch on a face, Fusion has its own algorithm for determining the origin and orientation of the sketch that isn't always predictable. In the sample above, I calculate the corner points of the rectangle in model space and then use the modelToSketchSpace method of the sketch to get the equivalent point in sketch space and then use that to create the rectangle. Hopefully, that makes sense.
I see!
Thank you very much! I will try to see if I manage to use it in other settings as well
