Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Select faces and move
0 REPLIES 0
Message 1 of 1
meister_mischler
84 Views, 0 Replies
Hi
I need some support with a script, which hopefully should generate a lasercutable shell of a low poly object.
The start is done with some help of ChatGPT. Sorry I'm not a coder. :winking_face:
The script generates all faces. I'm stuck a the point, where I want to alter these faces: As a first step the outline of the generated faces should get a bit smaller. At the moment I'm fine with a fixed value like the thickness of the shell (2mm). Later this should be replace with a value, which respects the angle between two faces (see the images below)
Can somebody provide hints how I can select and move the faces a bit inwards?
Very helpful would be, if I somehow can see the list of commands while I do the editing of the model by hand. Is there something like this available?
Sample Body: https://a360.co/41N9DbY
Expencted Result: https://a360.co/4iY5M1K
import adsk.core, adsk.fusion, adsk.cam, traceback
import math
def duplicate_and_extrude_faces():
    try:
        # Die Fusion-App-Instanz abrufen
        app = adsk.core.Application.get()
        ui = app.userInterface
        # Die aktive Design-Umgebung abrufen
        design = app.activeProduct
        if not design:
            ui.messageBox('Kein aktives Design gefunden.')
            return
        # Benutzer auffordern, einen Körper auszuwählen
        ui.messageBox('Bitte einen Körper auswählen, den Sie bearbeiten möchten.')
        selection = ui.selectEntity('Körper auswählen', 'Bodies')
        if not selection:
            ui.messageBox('Es wurde kein Körper ausgewählt.')
            return
        body = selection.entity
        if not isinstance(body, adsk.fusion.BRepBody):
            ui.messageBox('Das ausgewählte Objekt ist kein gültiger Körper.')
            return
        # Benutzer nach dem Offset-Wert fragen
        input_box = ui.inputBox('Bitte den Offset-Wert eingeben (negativ für innen):', 'Offset-Wert', '-1.0')
        if input_box is None:  # Wenn der Benutzer "Abbrechen" drückt
            return
        # Falls die Eingabe eine Liste ist, den ersten Eintrag verwenden
        if isinstance(input_box, list):
            input_box = input_box[0]
        try:
            offset_value = float(input_box)
        except ValueError:
            ui.messageBox('Der eingegebene Wert ist keine gültige Zahl.')
            return
        if offset_value >= 0:
            ui.messageBox('Bitte geben Sie einen negativen Wert ein, um nach innen zu extrudieren.')
            return
        # Korrektur für die Einheiten (wenn der Fehler mit Faktor 10 zu tun hat)
        offset_value = offset_value / 10  # Hier teilen wir durch 10, um den Faktor zu korrigieren
        # Körper duplizieren
        body_collection = adsk.core.ObjectCollection.create()
        body_collection.add(body)
        copy_feature = body.parentComponent.features.copyPasteBodies.add(body_collection)
        copied_body = copy_feature.bodies[0]
        # Ursprungskörper umbenennen und ausblenden
        body.name = 'Original'
        body.isVisible = False  # Der Körper wird ausgeblendet
        # Kopie des Körpers löschen
        copied_body.deleteMe()
        # Alle Flächen des Originalkörpers extrudieren
        face_collection = adsk.core.ObjectCollection.create()
        for face in body.faces:
            face_collection.add(face)
        # Flächen extrudieren und benennen
        extrude_features = body.parentComponent.features.extrudeFeatures
        shell_counter = 1
        original_face = None  # Variable zum Speichern der ursprünglichen Fläche
        for face in face_collection:
            # Extrusionseingabe erstellen
            extrude_input = extrude_features.createInput(
                face, adsk.fusion.FeatureOperations.NewBodyFeatureOperation
            extrude_input.setDistanceExtent(False, adsk.core.ValueInput.createByReal(offset_value))
            extrude_feature = extrude_features.add(extrude_input)
            # Den extrudierten Körper benennen
            extrude_feature.bodies[0].name = f'Shell_{shell_counter}'
            # Wenn es Shell_1 ist, speichern wir die ursprüngliche Fläche
            if shell_counter == 1:
                original_face = face
            shell_counter += 1
        # Ursprüngliche Fläche selektieren
        if original_face:
            ui.activeSelections.clear()  # Auswahl leeren
            ui.activeSelections.add(original_face)  # Ursprüngliche Fläche zur Auswahl hinzufügen
            ui.messageBox(f'Die ursprüngliche Fläche wurde erfolgreich selektiert.')
        else:
            ui.messageBox('Konnte die ursprüngliche Fläche nicht finden.')
    except Exception as e:
        if ui:
            ui.messageBox(f'Fehler:\n{traceback.format_exc()}')
# Funktion aufrufen
0 REPLIES 0
