Seeking basic transform examples for sketch objects
fliesblindthroughcrapstorms
I attempting to create repetative parameter driven objects which exceed what can be done with parameteric sketching. This is my first foray into the API, but I am familiar with Python. I can't seem to find any examples of how to set up the matrix to do basic transforms (rotation/translation) of sketch curves. Can anyone point me in the right direction?
kandennti
Hi @fliesblindthroughcrapstorms -San.
The following sample rotates the sketch curve of a given sketch.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
import math
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        msg: str = 'Select Sketch'
        selFilter: str = 'Sketches'
        sel: core.Selection = selectEnt(msg, selFilter)
        if not sel:
            return
        exec_rotation_sketchCurves(sel.entity, 45)
        ui.messageBox('Done')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def exec_rotation_sketchCurves(
    skt: fusion.Sketch,
    angle: float, # unit deg
) -> None:
    crvs = [c for c in skt.sketchCurves]
    if len(crvs) < 1:
        return
    mat: core.Matrix3D = core.Matrix3D.create()
    mat.setToRotation(
        math.radians(angle),
        core.Vector3D.create(0, 0, 1),
        core.Point3D.create(0, 0, 0),
    skt.move(
        core.ObjectCollection.createWithArray(crvs),
        mat,
def selectEnt(
    msg: str,
    filterStr: str
) -> core.Selection:
    try:
        ui: core.UserInterface = app.userInterface
        sel = ui.selectEntity(msg, filterStr)
        return sel
    except:
        return None
kandennti
This is how it works for translations.
        # exec_rotation_sketchCurves(sel.entity, 45)
        exec_translation_sketchCurves(
            sel.entity,
            core.Vector3D.create(10, 10, 0),
def exec_translation_sketchCurves(
    skt: fusion.Sketch,
    vec: core.Vector3D,
) -> None:
    if len(crvs) < 1:
        return
    mat.translation = vec
    skt.move(
        mat,
Thank you very much.
