Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Scripting does not allow sketching on any sketch plane.
0 REPLIES 0
Message 1 of 1
toyo6084
87 Views, 0 Replies
I am new to Fusion.
This f3d file has each cross section modeled using a script. When I start editing on a sketch plane, I cannot edit on that plane. For example, when I add a shape, it is drawn on the xy plane at Z=0.
I would like to be able to edit on the sketch plane I choose.
The attached txt file is the python code.
Thank you in advance for your help.
0 REPLIES 0
