Script to level the camera
michael
michael
I use the following when making screen shots to straighten up the view, making vertical lines plumb (in ortho mode). Even in perspective mode it helps improve consistency between shots of different parts of the model.
There are some potential edge cases (e.g. upVector perpendicular to y-axis), but for my intended use I don't expect to be operating anywhere near them. If there's a way in the UI that I missed to accomplish the same thing I'd love to know about it 🙂
Cheers,
Michael
#Description- LevelCamera.py
import adsk.core, adsk.fusion, adsk.cam, traceback
def decomposeVector(a, b):
    aParallelB = b.copy()
    aParallelB.scaleBy(a.dotProduct(b) / b.dotProduct(b))
    aPerpendicularB = a.copy()
    aPerpendicularB.subtract(aParallelB)
    return [aParallelB, aPerpendicularB]
def verticalizeView():
    ui = None
    app = adsk.core.Application.get()
    ui  = app.userInterface
    cam = app.activeViewport.camera
    yAxisVector = adsk.core.Vector3D.create(0.0, 1.0, 0.0)
    upVector = cam.upVector
    # construct vector pointing from camera to target
    eyeVector = adsk.core.Vector3D.create(cam.target.x - cam.eye.x, cam.target.y - cam.eye.y, cam.target.z - cam.eye.z)
    # Whenever view is level, Y-axis, upVector, and eyeVector will be coplanar.
    # To roll the camera to make it level, project the upVector to the plane
    # formed by Y-axis + eyeVector then rescale to get new upVector
    # make sure the request makes sense
    if yAxisVector.isParallelTo(eyeVector):
        # NOTE: above should really check instead to see if angle
        # between Y axis and eyeVector is closer than some arbitrary amount to 0 or pi
        ui.messageBox('Camera is pointing straight up or down')
    else:
        # get vector perpendicular to both yAxis + eyeVector
        orthoVector = yAxisVector.crossProduct(eyeVector)
        # isolate the portion of camera upVector that would remain once we project onto
        # vertically oriented plane containing eyeVector
        upParallel, upPerpendicular = decomposeVector(upVector, orthoVector)
        # stretch remainder back to unit length (don't know if Fusion cares)
        upPerpendicular.scaleBy(1/upPerpendicular.length)
        cam.upVector = upPerpendicular
        rotation = round(upVector.angleTo(upPerpendicular) * 360 / 6.283,1)
        app.activeViewport.camera = cam
        ui.messageBox('Done. Camera rotated by ' + str(rotation) + ' degree(s)')
def run(context):
    ui = None
    try:
        verticalizeView()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
ekinsb
I don't know of a built-in command in Fusion do this.  I believe this will accomplish the same thing in your case though.
    view = app.activeViewport
    cam = view.camera
    else:
        cam.upVector = yAxisVector
        view = cam
Brian Ekins
Mod the Machine blog
michael
Hmm, I tried your code and I didn't see any effect (but also did not get any exception either). It would indeed be much simpler if I could just set the upVector that way without worrying about maintaining perpendicularity with camera->target vector
I did figure out though that if I set Orbit to Constrained in UI before maneuvering for my screen shot that it eliminates need for my script 🙂
Michael
michael
PS: I pasted in the eyeVector line before trying to run:
