Script to automatically populate file name with operation notes when post processing.
jameswVTJ5V
jameswVTJ5V
Hi all,
Is there a way to automatically populate the file name with the contents of an operation's notes when post processing?
So I usually have a setup/s with various operations. Due to tech restrictions I have to post process each operation separately and rename them with an appropriate file name in the post dialog.
To make sense of them I create a file name in the operation notes and copy that into the file name when posting eg operation 1 notes might contain "SH1-SS-OP1" and file name is entered manually as "SH1-SS-OP1". The content of the notes is also used in the setup sheet to identify the operation and thus which files need to be machined in order.
A way to automate this would be awesome for 2 reasons. 1 it is tedious doing it manually and 2 (more importantly) it would eliminate errors when editing the file name. Is this achievable using a script?
Unfortunately I am no coder so if anyone is able to help that would be fantastic!
TIA
kandennti
Hi @jameswVTJ5V -San.
Words alone may not be what is intended.
Especially for CAM, since there are many setting items, it is most desirable to have the data attached.
This is a script that sets the first operation NOTES of the NC program that has already been created to the file name of the NC program.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.cam as cam
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        camObj: cam.CAM = get_cam_product()
        ncPros: cam.NCPrograms = camObj.ncPrograms
        if ncPros.count < 1: return
        infos = []
        for ncPro in ncPros:
            opes: cam.Operations = ncPro.operations
            if len(opes) < 1: continue
            ope: cam.Operation = opes[0]
            if ope.classType() == cam.Setup.classType():
                ope = ope.operations[0]
            fName = get_cam_parameter(
                ncPro,
                "nc_program_filename",
            notes = ope.notes
            if len(notes) < 1: continue
            set_cam_parameter(
                ncPro,
                notes,
            infos.append(f"{fName} -> {notes}")
        ui.messageBox("\n".join(infos))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def get_cam_parameter(
        camEntity,
    try:
        prm: cam.CAMParameter = camEntity.parameters.itemByName(
            name
        if not prm: return None
        return prm.value.value
    except:
        return None
def set_cam_parameter(
        camEntity,
        value: str,
) -> bool:
    try:
            name
        if not prm: return False
        prm.value.value = value
        return True
    except:
        return False
def get_cam_product() -> cam.CAM:
    activate_cam_env()
    return app.activeProduct
def activate_cam_env() -> None:
    ui: core.UserInterface = app.userInterface
    camWS: core.Workspace = ui.workspaces.itemById('CAMEnvironment')
    camWS.activate()
