Announcements
Script for movement plot or table (Motion Study Results)
rui_pessoa
Observer
rui_pessoa
Observer
Observer
Does anybody have solution to get the movement plot.
I want a plot or a excel table  of the position of joint  "slider12" in relation of "revolution2"
The drawing it's just a example.
Thanks in advance
BrianEkins
I think writing a program to do this should be possible, but I'm unaware of any that already exist. I think you would want a UI allowing you to pick the joint to drive, the joint(s) to get the results from, and then where to write the results. It shouldn't be that difficult to write, and I would give it a shot, but I'm busy with some other projects I need to get finished first.
Brian Ekins
kandennti
Hi @rui_pessoa .
I have created a sample that changes 'Revolute 2' every once in a while and exports the value of 'Slider 12' in a csv file.
More work needs to be done to make it usable beyond the attached data.
# Fusion360API Python script
import traceback
import adsk
import adsk.core as core
import adsk.fusion as fusion
import math
import csv
def run(context):
    ui = core.UserInterface.cast(None)
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        root: fusion.Component = des.rootComponent
        # get joints
        rev2: fusion.Joint = root.joints.itemByName('Revolute 2')
        sdr12: fusion.Joint = root.joints.itemByName('Slider 12')
        # get joint values
        dataLst = get_joint_values(
            rev2,
            sdr12,
            0,
            360,
            1
        # export csv
        path = r'C:\temp\test.csv'
        export_csv(path, dataLst)
        ui.messageBox('Done')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def get_joint_values(
    ref_joint: fusion.Joint,
    target_joint: fusion.Joint,
    minValue: float,
    maxValue: float,
    step: float,
) -> list:
    unitsMgr: core.UnitsManager = des.unitsManager
    ratio = unitsMgr.convert(
        1,
        unitsMgr.internalUnits,
        unitsMgr.defaultLengthUnits
    units = unitsMgr.defaultLengthUnits
    vp: core.Viewport = app.activeViewport
    dataLst = []
    app.executeTextCommand(u'Transaction.Start get_joint_values')
    for deg in frange(minValue, maxValue, step):
        rad = math.radians(deg)
        ref_joint.jointMotion.rotationValue = rad
        dataLst.append(
                deg,
                'deg',
                target_joint.jointMotion.slideValue * ratio,
                f'{units}',
        vp.refresh()
        adsk.doEvents()
    app.executeTextCommand(u'Transaction.Abort')
    return dataLst
def frange(start, end, step) -> list:
    list = [start]
    n = start
    while n + step < end:
         n = n + step
         list.append(n)
    return list
def export_csv(
    path: str,
    dataLst: list
) -> None:
    with open(path, 'w', newline='') as f:
        writer = csv.writer(f)
        writer.writerows(dataLst)
rui_pessoa
Observer
Observer
Thanks... fully working 🙂
