Script error when running through multiple files for CAM data
ArjanDijk
Advisor Advisor
ArjanDijk
I'm trying this script to get cycletimes from multiple files. I ran it on multiple projects succesfully, but run into 2 issues:
  1. My recent files gets fully populated by these file
  2. I get a script error without an idea whats the problem on some projects.
    about 2.  I seems to happen in the for loop "for files". How can I see what causes this error?
import adsk.core, adsk.fusion, adsk.cam, os, traceback, csv
from datetime import datetime, timedelta, timezone
# Initialize Fusion 360 application objects
app = adsk.core.Application.get()
ui = app.userInterface
def format_machining_time(minutes):
    #"""Converts machining time from minutes to hours:minutes:seconds format."""
    # Convert minutes to seconds for timedelta
    seconds = int(minutes * 60)
    # Use timedelta for easy conversion and formatting
    td = timedelta(seconds=seconds)
    # Format as hours:minutes:seconds
    return str(td)
def export_project_data_to_csv(output_folder):
    # Access the active project's root folder
    project_root = app.data.activeProject.rootFolder
    # Prepare the CSV file for output
    csv_path = os.path.join(output_folder, 'Fusion360_Project_Data.csv')
    # Open the CSV file
    with open(csv_path, mode='w', newline='', encoding='utf-8') as csv_file:
        csv_writer = csv.writer(csv_file, delimiter=',', quotechar='"', quoting=csv.QUOTE_MINIMAL)
        # Write the headers
        headers = ['Document Name', 'Creation Date', 'Last Updated', 'Setup Name', 'Machining Time (Minutes)', 'Thumbnail Path',"Total Operations", "Valid Operations"]
        csv_writer.writerow(headers)
        # Iterate through each file in the root folder
        for file in project_root.dataFiles:
            if file.fileExtension.lower() == 'f3d' or file.fileExtension.lower() == 'f3z':
                try:
                    document = app.documents.open(file, True)  # Open the document in read-only mode
                except:
                    ui.messageBox('Failed to open document:\n{}'.format(traceback.format_exc()))
                    continue
                products = document.products
                try:
                    product = products.itemByProductType('CAMProductType')
                except:
                    ui.messageBox('There are no CAM operations in the active document.  This script requires the active document to contain at least one CAM operation.',
                    'No CAM Operations Exist',
                    adsk.core.MessageBoxButtonTypes.OKButtonType,
                    adsk.core.MessageBoxIconTypes.CriticalIconType)
                    continue
                # product = document.products.itemByProductType('CAMProductType')
                cam = adsk.cam.CAM.cast(document.products.itemByProductType('CAMProductType'))
                # Document details
                creation_date = convert_epoch_to_dutch_datetime(file.dateCreated)
                last_update = convert_epoch_to_dutch_datetime(file.dateModified)
                # Generate thumbnail for the document
                thumbnail_path = generate_thumbnail(document.name, output_folder)
                # Iterate through CAM setups in the document
                for setup in cam.setups:
                    setup_name = setup.name
                    # Calculate actual machining time using the CAM API
                    try:
                        machTimeResult = cam.getMachiningTime(setup, 1, 100, 15)
                        machining_time_minutes = machTimeResult.machiningTime  # Time in minutes
                        machining_time_formatted = format_machining_time(machining_time_minutes)
                    except:
                        machining_time = "Error calculating time"
                    # Count total and valid operations based on Operation.isValid property
                    num_operations = setup.allOperations.count
                    num_valid_operations = sum(1 for op in setup.allOperations if op.isToolpathValid)
                    # Write details to the CSV file
                    csv_writer.writerow([
                        document.name, creation_date, last_update, setup_name, machining_time_formatted,
                        thumbnail_path, num_operations, num_valid_operations
            # Close the document after processing
            document.close(False)
    # Notify the user
    ui.messageBox('CAM project data and thumbnails exported to CSV successfully.')
def convert_epoch_to_dutch_datetime(epoch_time):
    # Assuming CET as UTC+1 for simplicity
    CET_OFFSET = timedelta(hours=1)
    UTC_ZONE = timezone.utc
    # Convert the epoch time to a datetime object in UTC
    utc_time = datetime.fromtimestamp(epoch_time, tz=UTC_ZONE)
    # Manually adjust for CET (without considering daylight saving time)
    dutch_time = utc_time + CET_OFFSET
    # Format the datetime object to a string in the desired format
    return dutch_time.strftime('%d-%m-%Y %H:%M:%S')
def generate_thumbnail(document_name, folder_path):
    try:
        # Get the active viewport
        viewport = app.activeViewport
        # Create a camera for isometric view
        camera = viewport.camera
        # Set the camera to look at the model isometrically
        camera.isSmoothTransition = False
        camera.viewOrientation = adsk.core.ViewOrientations.IsoTopRightViewOrientation
        # Apply the camera to the viewport
        viewport.camera = camera
        viewport.refresh()
        # Define the file name for the saved image
        file_name = f'thumbnail_{document_name}.png'
        file_path = os.path.join(folder_path, file_name)
        # Save the current viewport as an image
        viewport.saveAsImageFile(file_path, 400, 300)
        return file_path
    except:
        ui.messageBox('Failed to generate thumbnail:\n{}'.format(traceback.format_exc()))
        return ''
# Specify the output folder path
output_folder_path = 'C:/temp'
# Ensure the output folder exists
os.makedirs(output_folder_path, exist_ok=True)
# Execute the export function
export_project_data_to_csv(output_folder_path)
Inventor HSM and Fusion 360 CAM trainer and postprocessor builder in the Netherlands and Belgium.
ArjanDijk
