Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
script based projects
2 REPLIES 2
mojobility
324 Views, 2 Replies
Sometimes it's preferable to do modeling in scripts versus the gui.  In which case the models are merely output and the scripts are the core project files.  But I don't see an option to support this design style which ought to make the scripts be the cloud shared project files and allow models to be automatically discarded or kept locally without ever uploading them to the cloud.  Small scripts can make big models.  Uploading and downloading the output instead of the source files is wasteful of time and resources.
2 REPLIES 2
KrisKaplan
in reply to: mojobility
We do plan on having scripts being (at least optionally) stored in the cloud, associated with the user (synchronized to any machine you log in on), and sharable (like project items).  But the exact form that this will take or the timeline for this work has not been determined yet.  You should definitely post your ideas on how this would best satisfy your workflows in the IdeaStation to raise the visibility and collaboration.
Kris
Kris Kaplan
mojobility
in reply to: KrisKaplan
Kris, thanks for the info.  I was hesitant to post to the IdeaStation because I thought there might be some support for this already that I was missing.  I tried uploading scripts to a project but the uploads failed and I wasn't sure if I had failed to find the right approach or if scripts as part of a project was completely unsupported.  If it merits an IdeaStation post I want to think it through to avoid offering up a half baked thought with major flaws...
