Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Save Sketch To DWG File Using A Python Script
1 REPLY 1
isocam
189 Views, 1 Reply
Can anybody help???
I have created a simple sketch, for testing purposes, and extruded it.
The sketch will always be called "Sketch1" consisting of Lines, Arcs and Circles.
I want to be able to automatically save the sketch as a 2D AutoCAD "Dwg" file, when I run a Python script.
I do not want to manually select the sketch first as the sketch will always be called "Sketch1".
Can this be done?
Many thanks in advance!
Darren
1 REPLY 1
kandennti
in reply to: isocam
Hi @isocam .
You cannot export a sketch as a DWG file.
It is the same with the GUI.
Here is a sample of exporting as a DXF file instead.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-a627026a-27c7-4430-b38a-e51564a4a640
# Fusion360API Python script
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app :adsk.fusion.Application = adsk.core.Application.get()
        ui = app.userInterface
        des :adsk.fusion.Design = app.activeProduct
        root :adsk.fusion.Component = des.rootComponent
        skt = root.sketches.itemByName('Sketch1')
        if not skt:
            return
        exportDXF_Desktop(skt, 'hoge.dxf')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def exportDXF_Desktop(
    skt: adsk.fusion.Sketch,
    filename: str,
    import os
    desktop_dir = os.path.expanduser('~/Desktop')
    import pathlib
    path = pathlib.Path(desktop_dir, filename)
    skt.saveAsDXF(str(path))
