Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Save scripts to A360 cloud?
2 REPLIES 2
SGoldthwaite
425 Views, 2 Replies
I use Fusion 360 on several different computers.  I haven't really used scripts before, but I came across a couple I plan to install.  Can I save these files to the A360 cloud, just like I do with CAM tool library and post processor files?  If not, can I save to a specific folder? I would choose a dropbox folder - which would give me essentially the same benefit as using A360 cloud.
2 REPLIES 2
david_reaume
in reply to: SGoldthwaite
For now, scripts in the Cloud are not supported.  Of course you can upload any kind of file you like to A360 but if you're dealing with scripts, you will need to download them to each device.  I see no reason why using your Box sync folder for scripts you want to share accross devices shouldn't work but I have not actually tried that myself yet.
DaVeR
DaVeR
SGoldthwaite
in reply to: david_reaume
I saved a script to my dropbox folder and this seems to work fine.
