Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Save "Project Folder" names to an ascii text files
1 REPLY 1
isocam
120 Views, 1 Reply
Can Anybody help?
Is it possible to save all the folder names, contained in the "Projects Folder" only to a asci text file?
Please see the attached picture for an example of the folder structure.
So that the text file would be something like.....
0101 - Darrens Test Folder
1000 - Silo Foot
1005 - Sand Silo Leg
1010 - Silo Fill Bend
etc
etc
Many thanks in advance!!
Darren
1 REPLY 1
BrianEkins
in reply to: isocam
Here's a little script that will do it. Remember that folders can contain other folders to any depth. This script recursively traverses the entire folder structure and will indent for each level.
def run(context):
    app = adsk.core.Application.get()
    ui = app.userInterface
    try:
        project = app.data.activeProject
        folders = ''
        result = getFolders(project.rootFolder, folders, 0)
        with open('C:\Temp\FolderList.txt', 'w') as f:
            f.write(result)
    except:
        ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def getFolders(currentFolder: adsk.core.DataFolder, folderList: str, level: int) -> str:
    folder: adsk.core.DataFolder
    for folder in currentFolder.dataFolders.asArray():
        # Create spaces for the indent depending on the current level.
        spaces = ' ' * (level * 2)
        if folderList == '':
            # Add the name of the first folder.
            folderList = spaces + folder.name
        else:
            # Add the name of all other folders with a newline before it.
            folderList += '\n' + spaces + folder.name
        # Recursively call this function to get any child folders.
        folderList = getFolders(folder, folderList, level + 1)
    return folderList
Brian Ekins
