Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Save Dxf file Automatically
1 REPLY 1
isocam
250 Views, 1 Reply
Can anybody help???
I have the following script file:
import adsk.core, adsk.fusion, traceback
import os
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        sketches = []
        for seln in ui.activeSelections:
            sketch = adsk.fusion.Sketch.cast(seln.entity)
            if sketch:
                sketches.append(sketch)
            for sketch in sketches:
                fullpath = os.path.join('C:\Pda', sketch.name)
                ui.messageBox(fullpath)
                sketch.saveAsDXF(fullpath + '.dxf')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
When I run it, I need to firstly, manually select the sketch.
Is there any way that the above script can be modified so that "Sketch1" is always automatically selected without me having to manually select it first???
Many thanks in advance!!!!!
Darren
1 REPLY 1
erik
in reply to: isocam
If you know in what component the sketch is located and the name of the sketch you can use the following code to get the sketch.
import os
def run(context):
    ui = None
    try:
        design = app.activeProduct
        rootComp = design.rootComponent
        sketch = rootComp.sketches.itemByName("SketchName")
    except:
        if ui:
The code will retrieve a sketch named: SketchName located in the root component.
If you have any further questions or this didn't solve the issue please write again.
- Erik
