Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
RuntimeError: 3: Environment is not supported
4 REPLIES 4
368 Views, 4 Replies
Hi, experts in Fusion360!
I met a problem when I want to create a construction point using following code:
# create a geo point
        point1 = adsk.core.Point3D.create(0, 20, 0)
        cons_points = rootComp.constructionPoints
        cons_point_input = cons_points.createInput() # create a constructionPointInput var
        cons_point_input.setByPoint(point1) # set by point
        point = cons_points.add(cons_point_input)
        geo_point = adsk.fusion.JointGeometry.createByPoint(point)
And the problem came out:
What is the "Environment" mean here? Is the python environment or the Fusion360 environment?
I search for the error "RuntimeError: 3: Environment is not supported" in google and this forum but do not find any thing.
Hoping for the community's help.
Thanks a lot!
And Merry Christmas to all the community and the Fusion360 experts!
4 REPLIES 4
j.han97
in reply to: 11713013
Hi @11713013 ,
Are you working in parametric design mode (with capture design history ON)? In the documentation here, it is stated that this line
constructionPoint = constructionPoints.add(input)
only works in direct edit mode (turn OFF capture design history).
Hope it helps.
in reply to: j.han97
You are right! After turn off Capture Design History, it works.
Thank you so much!
Merry Christmas!
j.han97
Merry Christmas!
