Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
RuntimeError: 2 : InternalValidationError : bBody ?
2 REPLIES 2
OceanHydroAU
275 Views, 2 Replies
Google says:
Your search - "InternalValidationError" "bBody" - did not match any documents.
So, frustratingly, this worked manually in the vscode console a few days ago, and I foolishly didn't take good notes or code it up then (in my defence - it *was* midnight...).  To make matters worse, the vscode console history irritatingly seems to have lost part of my work (seems if you hit up-arrow later, it overwrites former commands - a bug in vscode - arrgh)
Anyhow - Now, my code fails, so I'm trying again to do this in the console, but this time: no luck.  Grrr.
myloft
<adsk.fusion.LoftFeature; proxy of <Swig Object of type 'adsk::core::Ptr< adsk::fusion::LoftFeature > *' at 0x1a16034b0> >
surfaces = adsk.core.ObjectCollection.create()
surfaces.add(myloft)
True
section[8]['foil']['patch']
<adsk.fusion.PatchFeature; proxy of <Swig Object of type 'adsk::core::Ptr< adsk::fusion::PatchFeature > *' at 0x1a2bf6360> >
surfaces.add(section[8]['foil']['patch'])
True
stitchInput = stitches.createInput(surfaces, tolerance, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
stitch = stitches.add(stitchInput)
Does anyone have any suggestions?
I'm assuming that the LoftFeature and the PatchFeature objects are the correct things to put into the surfaces collection?  Although the "bBody" word is making me wonder if I'm supposed to get/use something else for one of those?
2 REPLIES 2
OceanHydroAU
in reply to: OceanHydroAU
Sample:
#Author-Chris
#Description-demo loft from http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-a03e26b4-4a3c-11e6-a2e4-3417ebd41e19
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
         # Create a document.
        doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        rootComp = design.rootComponent
        # Create profile 1
        sketchesObj = rootComp.sketches
        sketch0 = sketchesObj.add(rootComp.xZConstructionPlane)
        sketchCirclesObj0 = sketch0.sketchCurves.sketchCircles
        centerPoint = adsk.core.Point3D.create(0, 0, 0)
        sketchCirclesObj0.addByCenterRadius(centerPoint, 5.0)
        profile0 = sketch0.profiles.item(0)
        # Create profile 2
        ctorPlanes = rootComp.constructionPlanes
        ctorPlaneInput1 = ctorPlanes.createInput()
        offset = adsk.core.ValueInput.createByString("10 cm")
        ctorPlaneInput1.setByOffset(rootComp.xZConstructionPlane, offset)
        ctorPlane1 = ctorPlanes.add(ctorPlaneInput1)
        sketch1 = sketchesObj.add(ctorPlane1)
        sketchCirclesObj1 = sketch1.sketchCurves.sketchCircles
        sketchCirclesObj1.addByCenterRadius(centerPoint, 2.0)
        profile1 = sketch1.profiles.item(0)
        # Create profile 3
        ctorPlaneInput2 = ctorPlanes.createInput()
        ctorPlaneInput2.setByOffset(ctorPlane1, offset)
        ctorPlane2 = ctorPlanes.add(ctorPlaneInput2)
        sketch2 = sketchesObj.add(ctorPlane2)
        sketchCirclesObj2 = sketch2.sketchCurves.sketchCircles
        sketchCirclesObj2.addByCenterRadius(centerPoint, 10.0)
        profile2 = sketch2.profiles.item(0)
        # Create loft feature input
        loftFeats = rootComp.features.loftFeatures
        loftInput = loftFeats.createInput(adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        loftSectionsObj = loftInput.loftSections
        loftSectionsObj.add(profile0)
        loftSectionsObj.add(profile1)
        loftSectionsObj.add(profile2)
        loftInput.isSolid = False
        surface1=loftFeats.add(loftInput)
        # Now make some patches too
        patches = sketch0.parentComponent.features.patchFeatures # patches = rootComp.features.patchFeatures
        patchInput = patches.createInput(profile0, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        patch0=patches.add(patchInput)
        patchInput = patches.createInput(profile2, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        patch2=patches.add(patchInput)
        # Now stitch them together
        surfaces.add(patch0)
        surfaces.add(surface1)
        # Define tolerance with 1 cm.
        tolerance = adsk.core.ValueInput.createByReal(1.0)
        # Create a stitch input to be able to define the input needed for an stitch.
        stitches = rootComp.features.stitchFeatures
        # Create a stitch feature.
        worked=1
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
OceanHydroAU
:sports_medal:(award for answering the most number of his own questions in one day...)
Turns out I need to add a "sub part"   .bodies.item(0)  of those things:
        surfaces.add(patch0.bodies.item(0))
        surfaces.add(surface1.bodies.item(0))
... looks like someone forgot to check input types on that API function call.
