Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Run script from external python script, automated
2 REPLIES 2
a.wendler
406 Views, 2 Replies
I am working with separate programs and programming languages which produce date for 3D-modelling. Now I need to send that data (e.g. coordinates) from the external programs to a fusion 360 python script or addin which deals with the data and e.g. creates or modifies my already loaded model.
Is there a way to let external software communicate with the scrips and addins or at least trigger them to start without me manually doing so. Ideally I could thus ‘control’ Fusion 360 from the external program.
Labels (1)
  • API
2 REPLIES 2
JesusFreke
in reply to: a.wendler
You can use any of the normal IPC mechanisms. E.g. you could have a fusion script that listens on a tcp port on localhost, and have your external script connect to that port and send data.
Here's an example from an add-in of mine that listens for http and ssdp requests:
https://github.com/JesusFreke/fusion_idea_addin/blob/master/fusion_idea_addin.py#L164
a.wendler
Thanks for the reply.
I would like to get the connection running without having to rely on network communication.
I managed to get a named pipe connection running between c# and python. However only if the python script doesn't run within Fusion360. As soon as I want the python script to run within Fusion360 the libraries
win32pipe and win32file "couldn't be found". I guess that is due to the fact that Fusion comes with its own python. Is there a way to get third party library running so that Fusion recognises them?
