Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Run press pull command with script.
1 REPLY 1
thomas_vijf
463 Views, 1 Reply
i have made a script that selects all cylindrical faces in a body, after wich i manualy press the 'press/pull' command button in the ribbon so i can change the fillet size.
I was wondering if there is a way to fire that press/pull button in the end of the script.
#Update SelectionSets
        cmd = ui.commandDefinitions.itemById('UpdateSelectionGroupCmd')
        cmd.execute()
I found this snippet to press the 'update selectionset' button.
I hope there is something simmilar to execute other standard button commands.
Thanks.
-Thomas
1 REPLY 1
BrianEkins
in reply to: thomas_vijf
You can start any command, including those added by add-ins, by accessing the related CommandDefinition object and executing it.  The trick is finding the CommandDefinition.  Here's a little script that can help with that.  It creates a file that contains a list of all the commands defined in your copy of Fusion 360.
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        result = ''
        cmdDef = adsk.core.CommandDefinition.cast(None)
        for cmdDef in ui.commandDefinitions:
            if result == '':
                result = cmdDef.name + ', ' + cmdDef.id
            else:
                result += '\n' + cmdDef.name + ', ' + cmdDef.id
        output = open('c:\\temp\\FusionCommands.txt', 'w')
        output.writelines(result)
        output.close()
        ui.messageBox('Finished wrting to c:\\temp\\FusionCommands.txt')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
After a quick search in the output file I find the line:
Press Pull, FusionPressPullCommand
This means you can use the following line to execute the Press Pull command in your program.
cmd = ui.commandDefinitions.itemById('FusionPressPullCommand')
cmd.execute()
Brian Ekins
