Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Run on Startup Issues
1 REPLY 1
luke-dempsey
340 Views, 1 Reply
I have altered the Parameter IO Add-In to have some more features.
It works fine, however, I cannot get it to run on startup.
I have it set to true in my .manifest file, it is also checked in the AddIns menu. It works fine when I manually launch it, but I just can't get it to run on startup.
"runOnStartup":	true,
My code is at https://github.com/lukedempsey/ParameterIO_Python/tree/add-export-only-user-params-option
(note that it is on the 'add-export-only-user-params-option' branch)
Even just advice on how to debug this would be great
Luke
1 REPLY 1
marshaltu
in reply to: luke-dempsey
I gave a quick testing and found the error as below when I tried to run the addin.
Marshal
>>> > c:\users\tum\downloads\parameterio_python-add-export-only-user-params-option\parameterio.py(4)<module>()
-> import adsk.core, adsk.fusion, traceback
(Pdb) continue
Traceback (most recent call last):
  File "<string>", line 2, in <module>
  File "C:/Users/tum/AppData/Local/Autodesk/webdeploy/production/8b78d7040dfea4f390bf2e76e5fd15ae50511bb0/Spyder\fusionspyderIPC.py", line 190, in debug_script
    sys.debugger.run(statement, global_dict, local_dict)
  File "C:\Users\tum\AppData\Local\Autodesk\webdeploy\production\8b78d7040dfea4f390bf2e76e5fd15ae50511bb0\Python\lib\bdb.py", line 431, in run
    exec(cmd, globals, locals)
  File "<string>", line 1, in <module>
  File "c:\users\tum\downloads\parameterio_python-add-export-only-user-params-option\parameterio.py", line 5, in <module>
    from . import utils
ImportError: cannot import name 'utils'
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
