Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Run Fusion 360 API "Python" Script When Opening An Existing Document (Assembly, Part or Drawing)
2 REPLIES 2
isocam
126 Views, 2 Replies
Can anybody help?
Is it possible to run a Fusion 360 API "Python" script when opening an existing document (Assembly, Part or Drawing)?
For example,
Whenever I open an existing Assembly, Part or Drawing (For testing purposes only) show a messagebox saying "Hello World"
Many thanks in advance!
Darren
2 REPLIES 2
j.han97
in reply to: isocam
I think your task is do-able. You might want to take a look at Application.documentOpened command here: Fusion 360 Help | Application.documentOpened Event | Autodesk. This event is triggered at the end of opening a document.
*Edit to correct weird hyperlink behavior
kandennti
in reply to: isocam
