Run external script from add-in
brad.bylls
brad.bylls
I am trying to run an external script from my add-in.
I have added to my add-in:
import adsk.core, adsk.fusion, traceback
from .SHCS import shcs <<<<<  Added
from .FHSCS import fhscs <<<<<  Added
handlers = []
def run(context😞
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        cmdDefs = ui.commandDefinitions
========== More code
class ShcsExecuteHandler(adsk.core.CommandEventHandler😞
    def __init__(self😞
        super().__init__()
    def notify(selfargs😞
        eventArgs = adsk.core.CommandEventArgs.cast(args)
        # Code to react to the event.
        gotoShcs = shcs() <<<<< Changed from a message box that works, so I know it gets here.
========== Rest of the code
In the external script (SHCS.py which worked as a plain script) I have:
import math, os
def shcs(): <<<<<  Added and tabbed over the rest of the code till end
    # Globals
    _app = adsk.core.Application.cast(None)
    _ui = adsk.core.UserInterface.cast(None)
    strUnits = ''
While debugging, it goes thru the add-in script with no errors until:
        gotoShcs = shcs()
It then just sits there and does nothing.
I think I'm close from what I've seen in the forums, just can't figure it out.
Brad Bylls
KrisKaplan
It's a little hard to guess. But this general behavior of "debug stepping through the code and it just stops, and going back to Fusion it's like my command just stopped" often means there was an uncaught exception. I would recommend following the addin samples in adding a 'try: catch:' block around all the code in all of your 'notify' functions on your event handlers, and do something with the exception info (log it, or in debug message it). I would expect you could get something useful from the message, or better yet the formatted traceback.
Kris
Kris Kaplan
brad.bylls
I looked all through the add-in examples and searched for catch: and found nothing.
So I tried this with 'try:'
# Event handler for the shcs execute event.
    try:
        def __init__(self😞
            super().__init__()
            #subprocess.run([sys.executable, 'SHCSCS'])
            gotoShcs = shcs()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
It didn't help. No exceptions came up. Just went into core.py and stopped.
Brad
Brad Bylls
pludikar
Hi @brad.bylls
If you haven't resolved this yet I'd suggest you try a couple of things:
  1. tighten down the try/except block
class ShcsExecuteHandler(adsk.core.CommandEventHandler‌‌
        def __init__(self‌‌
            super().__init__()
        def notify(self, args‌‌
            try:
                gotoShcs = shcs()
            except:
                if ui:
                   ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))​
and see if that throws any useful traceback messages
  • If that doesn't do anything useful - try putting a break in the notify def block, and once the code breaks, execute the shcs() statement in the immediate debug console command line.  If there are any traceback messages to be had, they'll show up then.
If nothing else this will verify that your shcs function actually works - if it does then it's almost certainly a F360 python API bug, and the F360 team can take it from there.
I hope that helps you move forward.
Peter
I'm not an expert, but I know enough to be very, very dangerous.
Life long R&D Engineer (retired after 30+ years in Military Communications, Aerospace Robotics and Transport Automation).
