Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
RigidGroup error
2 REPLIES 2
MichaelT_123
253 Views, 2 Replies
RigidGroup error
Hi T_F360,
Could you please look at the code around RigidGroup object.
I do experience the global error as loged below:
for rGrup in comp.allRigidGroups:
if ( rGrup.isSuppressed 😞 # <=== ERROR
ERROR LOG START
25 Oct 2017 16:17:51.244520
Global error
Traceback (most recent call last):
File "C:/Fusion360/API/Scripts/XXXX.py", line XXXX, in listRigidGroups
File "XXXX/Api/Python/packages\adsk\fusion.py", line 22788, in _get_isSuppressed
return _fusion.RigidGroup__get_isSuppressed(self)
RuntimeError: 2 : InternalValidationError : jointOcc
During handling of the above exception, another exception occurred:
SystemError: <built-in function delete_RigidGroupVector> returned a result with an error set
SystemError: <built-in function delete_SwigPyIterator> returned a result with an error set
ERROR LOG END
 Perhaps the issue is related to a linked component .... not so sure though.
It is not the argent problem. I can deal with it, but if you any ???? chance will have nothing to do ... just look whats going there :).
Regards
MichaelT
MichaelT
Tags (1)
2 REPLIES 2
I’ve asked the forum moderator to move this to the API section as you’ll likely get better support.
Peter Doering
ekinsb
in reply to: MichaelT_123
I tried to reproduce the problem but without any success.  I have an assembly that contains groups in both the root component and in an assembly from an external reference and the isSuppressed property is working correctly for all cases.  There must be a specific issue in your case.  Is it possible to provide a design and a simple script that demonstrates the problem?
Brian Ekins
Mod the Machine blog
