Revolve 2 profiles
Revolve 2 profiles
Revolve 1 profile
     Ptr<Profiles> profs = sketch2->profiles();
	Ptr<Profile> prof = profs->item(0);
	Ptr<RevolveFeatures> revolves = rootComp->features()->revolveFeatures();
	Ptr<RevolveFeatureInput> revInput = revolves->createInput(prof, sketchLine1, FeatureOperations::NewBodyFeatureOperation);
	Ptr<ValueInput> angle = ValueInput::createByReal(360.0);
	revInput->setAngleExtent(false, angle);
	revolves->add(revInput);
How revolve 2 profile by 1 operation?
Thank`s.
marshaltu
I am not sure if it is too late to reply to the post. Please refer to the following sample how to create revolve feature with multiple profiles.
Marshal
import adsk.core, adsk.fusion, traceback
def run(context):
  ui = None
  try:
    app = adsk.core.Application.get()
    ui  = app.userInterface
    design = adsk.fusion.Design.cast(app.activeProduct)
    root = design.rootComponent
    sketch = root.sketches.item(0)
    profiles = adsk.core.ObjectCollection.create()
    for profile in sketch.profiles:
        profiles.add(profile)
    revolves = root.features.revolveFeatures
    input = revolves.createInput(profiles, sketch.sketchCurves.sketchLines.item(0), adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
    input.setAngleExtent(True, adsk.core.ValueInput.createByString('180 deg'))
    revolves.add(input)
  except:
    if ui:
      ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Marshal Tu
Fusion Developer
