Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
reverse normal of BRepFace
2 REPLIES 2
megumin.mnmhara
192 Views, 2 Replies
Hi, everyone.
I want to reverse the normal vector of BRepFace by fusion360 API.
I know that I can do it using this command shown in the photo.
But, is there no way to do this by fusion360 API?
If you know the solution, can you tell me it?
Thank you.
2 REPLIES 2
You can use the API to create a ReverseNormalFeature, which is the same thing that's created when you reverse a normal in the UI.
Brian Ekins
Thank you!
I can do it using the feature.
