Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Repalce DocumentReference
2 REPLIES 2
-pezi-
104 Views, 2 Replies
I want do make replace dataFile in allDocumentReferences() something as
Ptr<DocumentReferences> refs = activeDoc->allDocumentReferences();
for (size_t i = 0; i < refs->count(); i++)
   Ptr<DocumentReference> docRef = refs->item(i);
   Ptr<DataFile> refDataFile = docRef->dataFile();
   Ptr<DataFile> copyRefDataFile = docRef->dataFile()->copy(folder);
   copyRefDataFile->name("Prefix_" + to_string(i));
   refDataFile = copyRefDataFile;
I know that this way isn't possible. My question is: there any way how this does it?
2 REPLIES 2
BrianEkins
in reply to: -pezi-
Does Fusion support this in the user interface.  All I could find was a way to switch which version of a design you're referencing.  Not switch to a completely different design.  Even if it can be done through the UI, the API doesn't support it.
Brian Ekins
-pezi-
in reply to: BrianEkins
Thank you for your response. I came to the same conclusions, I just wanted to make sure I didn't miss some way to do it using the API.
