Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Reference to bRepBody Create from an Extrusion
3 REPLIES 3
codefoster
251 Views, 3 Replies
If I (via the API) create a sketch and then extrude it, a bRepBody is created. How do I get a reference to that body without having to use some sort of logic to select it. I want the body that resulted from the extrusion.
3 REPLIES 3
liujac
in reply to: codefoster
You may add attributes to the BRepBody and find the BRepBody by attributes. Please read: http://fusion360.autodesk.com/learning/learning.html?guid=GUID-BAF017FE-10B8-4612-BDE2-0EF5D4C6F800.
Jack
ekinsb
The ExtrudeFeature object supports the bodies property which returns the body(s) that were created or modified by the feature.  If you specified that a new body should be created by the feature, then this will return the new single new body.
Brian Ekins
Mod the Machine blog
codefoster
in reply to: ekinsb
Great. I think this will be my solution. Thanks, Brian.
