Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Reading texture data associated with meshes
3 REPLIES 3
cfurness
289 Views, 3 Replies
I have a mesh which I have imported into Fusion 360. I have added an appearance for every body and verified that this appearance is associated with an image file. It appears textured within Fusion360.
However when I iterate over the TriangleMesh entities in custom script (C++ code), hasTexture() returns false for every mesh. They are clearly the correct meshes however since the triangle data matches what I expect to see.
Am I looking for the texture data in the wrong place? I would have expected the hasTexture() to return true, and for the texture coordinates on the TriangleMesh to be populated.
Any help appreciated.
3 REPLIES 3
ekinsb
in reply to: cfurness
Unfortunately, access to the textures is not currently supported by the API.
Brian Ekins
Mod the Machine blog
cfurness
in reply to: ekinsb
Is there an ETA on this feature? Like weeks/months/not for the foreseeable future?
ekinsb
Hopefully sooner than this but right now I would have to say it's not in the foreseeable future.  There are a couple of issues with us exposing this.  One is an internal issue that we're waiting on and the second is the more extensive use of sophisticated shaders so there's not a simple texture available.
Brian Ekins
