Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Read property from the design with Api
1 REPLY 1
sandeep.guliani
91 Views, 1 Reply
Dear Fusion-Community,
I want to read/extract the properties from any design. I am trying to write a script that can help me read specifications like length, breadth, radius, height, angle etc.
From the samples, I could learn and find the count of Features.
       ui  = app.userInterface
       product = app.activeProduct
       design = adsk.fusion.Design.cast(product)
       sketch = design.rootComponent.sketches
    #all Features
        features = design.rootComponent.features
     #Hole Features
        holff = features.holeFeatures
    #Features count
        print(holff.count)
     #Extrude Features
        extff = features.extrudeFeatures
    #Features count
        print(extff.count)
But I want to extract the specifications of a specific feature details.
I am looking for some help and guidance.
1 REPLY 1
@sandeep.guliani One can get read a property from the respective feature object. Here is a sample script to know the properties of a hole feature like diameter, center, and length.
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        for hole_feature in features.holeFeatures:
            app.log(str(f'--------{hole_feature.name}------'))
            app.log(str(f'Dia: {hole_feature.holeDiameter.expression}'))
            app.log(str(f'Center: {hole_feature.position.x}, {hole_feature.position.y}, {hole_feature.position.z}'))
            app.log(str(f'Length: {hole_feature.extentDefinition.distance.expression}'))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Here is a link to HoleFeature object help document https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-GUID-3315b7ea-f85d-417c-ad31-2d328b72f6a5
If you go through the correct property you will find the required value.
Similarly, you need to refer to other feature objects' properties to read the value.
Here is a link for ExtrudeFeature object https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-GUID-62d132d3-2ae9-4d74-91d1-f2eee3d68f5d
Hope it helps.
If my reply was helpful, please click the "Accept as Solution" button. It helps others get the answer quickly! A "Like" is always welcomed
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
