Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Read File Version from API?
3 REPLIES 3
ahalekelly
402 Views, 3 Replies
I'm writing a script to engrave information about the design into the part and then export an STL for 3D printing. I've figured out how to do this with model parameters, but I can't figure out how to read the version number of the file within the API. Is this possible?
3 REPLIES 3
JeromeBriot
in reply to: ahalekelly
here is a Python code to get the lastest version number:
import adsk.core, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        doc = app.activeDocument
        df = doc.dataFile
        ui.messageBox('{}'.format(df.latestVersionNumber))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Read the documentation about the DataFile Object.
Hope this helps.
ahalekelly
in reply to: JeromeBriot
Thank you! That works great.
BrianEkins
Just be aware that the version being returned is the latest saved version of the design.  If you open an existing design and make changes to it, it's theoretically a new version but that new version isn't actually created until you save it.
Brian Ekins
