"operation not permitted" when writing a file
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I am trying to create a simple add-in in python, simply to save a body to an STL file. I am a complete noob at the Fusion 360 API, and the learning curve is steep, it always crashed without any meaning error message!
I was about to get things going, when I got this error message when saving the file: "PermissionError: Operation not permitted".
I am suspecting some Mac OS process sandboxing issue, but it has to be noted that I can save an STL file manually from Fusion 360 in the same directory, so it's not a complete interdiction.
here is the message:
here is the work in progress:
import json
import adsk.cam
import adsk.core
import adsk.fusion
import traceback
USER_PARAM = 'exporter_stl'
keepHandlers = []
deletableObjects = []
def find_brep(chain, component, ui):
if len(chain) > 1:
if component.objectType == 'adsk::fusion::Component':
child = component.occurrences.itemByName(chain[0])
else:
child = component.childOccurrences.itemByName(chain[0])
return find_brep(chain[1:], child, ui)
elif len(chain) == 1:
return component.bRepBodies.itemByName(chain[0])
return None
class ExportCommandCreatedEventHandler(adsk.core.CommandCreatedEventHandler):
def notify(self, args):
cmd = args.command
app = adsk.core.Application.get()
ui = app.userInterface
try:
design = app.activeProduct
dir_param = design.userParameters.itemByName(USER_PARAM)
data = None
if dir_param:
data = json.loads(dir_param.comment)
else:
dialog = ui.createFileDialog()
dialog.title = 'Select export file'
dialog.filter = '*.*'
result = dialog.showSave()
if result == adsk.core.DialogResults.DialogOK:
file_name = dialog.filename
ui.messageBox('select body')
selected = ui.selectEntity('select body', 'Bodies,MeshBodies')
entity = selected.entity
chain = [entity.name]
obj = entity
while True:
obj = obj.assemblyContext
if obj:
chain.append(obj.name)
else:
break
data = {'file': file_name, 'chain': list(reversed(chain))}
json_params = json.dumps(data)
design.userParameters.add(USER_PARAM, adsk.core.ValueInput.createByString('0'), '', json_params)
if data:
body = find_brep(data['chain'], design.rootComponent, ui)
if body:
ui.messageBox('body found: ' + body.name)
exportMgr = design.exportManager
ui.messageBox('file: ' + data['file'])
with open(data['file'] + '.txt', 'w') as out_file:
out_file.write('whatever')
stl_export_options = exportMgr.createSTLExportOptions(body)
stl_export_options.sendToPrintUtility = False
stl_export_options.meshRefinement = 0
stl_export_options.filename = data['file']
exportMgr.execute(stl_export_options)
else:
ui.messageBox('.'.join(data['chain']) + 'not found')
except:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def run(context):
try:
print('STARTING')
cmdDefs = ui.commandDefinitions
myButton = ui.commandDefinitions.itemById('ExportDesign')
if myButton:
myButton.deleteMe()
myButton = cmdDefs.addButtonDefinition('ExportDesign', 'Export STL', 'Export the design in various formats.')
onCommandCreated = ExportCommandCreatedEventHandler()
myButton.commandCreated.add(onCommandCreated)
keepHandlers.append(onCommandCreated)
ui.allToolbarPanels.itemById('SolidMakePanel').controls.addCommand(myButton, '', False)
except:
if ui:
def stop(context):
ui = None
try:
button = ui.commandDefinitions.itemById('ExportDesign')
if button:
button.deleteMe()
global keepHandlers
keepHandlers = []
# for obj in deletableObjects:
# obj.deleteMe()
except:
if ui:
thanks for your help.
