Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
"Failed to get owner occurrence transform" - Rectangular Pattern of Occurrences
1 REPLY 1
Mr.Stephen-K
94 Views, 1 Reply
I am running into an error using the API while trying to perform a Rectangular Pattern on an occurrence of a component.
In general, I am trying to create a new "Parent" component / occurrence in a design that will hold "Child" hardware component occurrences.  The script successfully creates the "Parent" component / occurrence activates the new occurrence creates the "Child" hardware occurrences and pattens them.  However, when I review the Timeline the Rectangular Pattern features show "yellow / sick" and have the following error:
Double clicking / opening the sick pattern feature and closing resolves the "sick / yellow" warning and the pattern seems to be stable.
Below is the "Generalized" section of code used to perform this operation:
import adsk.core, adsk.fusion, adsk.cam, traceback
app: adsk.core.Application = adsk.core.Application.get()
product = app.activeProduct
design = adsk.fusion.Design.cast(product)
ui = app.userInterface
root = design.rootComponent
vector = adsk.core.Vector3D.create(0.0, 0.0, 0.0)
transform = adsk.core.Matrix3D.create()
transform.translation = vector
parent_part_occ = root.occurrences.addNewComponent(transform)
parent_part_occ.component.name = "Parent Part"
parent_part_occ.component.description = "Parent Part"
#create parts list to add occurrances
child_parts_add_list = ['123', '456', '789']
child_parts_add_qty = ['16', '2', '1']
child_parts_add_desc = ["Name 1", "Name 2", "Name 3"]
parent_part_occ.activate = True
for part, qty, desc in zip(child_parts_add_list, child_parts_add_qty, child_parts_add_desc):
       new_occ = parent_part_occ.component.occurrences.addNewComponent(transform)
       new_occ.component.name = desc
       new_occ.component.description = desc
       new_occ.component.partNumber = part
       if int(qty) > 1:
              # Create input entities for rectangular pattern
              inputEntites = adsk.core.ObjectCollection.create()
              inputEntites.add(new_occ)
              # Get x and y axes for rectangular pattern
              xAxis = root.xConstructionAxis
              yAxis = root.yConstructionAxis
              # Quantity and distance
              quantityOne = adsk.core.ValueInput.createByString(qty)
              distanceOne = adsk.core.ValueInput.createByString('1 in')
              quantityTwo = adsk.core.ValueInput.createByString('1')
              distanceTwo = adsk.core.ValueInput.createByString('0 in')
              # Create the input for rectangular pattern
              rectangularPatterns = parent_part_occ.component.features.rectangularPatternFeatures
              rectangularPatternInput = rectangularPatterns.createInput(inputEntites, xAxis, quantityOne, distanceOne, adsk.fusion.PatternDistanceType.SpacingPatternDistanceType)
              # Set the data for second direction
              rectangularPatternInput.setDirectionTwo(yAxis, quantityTwo, distanceTwo)
              # Create the rectangular pattern
              rectangularFeature = rectangularPatterns.add(rectangularPatternInput)
              rectangularFeature.name = "Pattern " + desc
              inputEntites.clear
parent_part_occ.activate = False
I am wondering what this error means and how to avoid the code from causing the Rectangular Pattern to be created with this warning.  It seems suspect that a open / close of the feature resolves the issue.
Thank you,
1 REPLY 1
kandennti
in reply to: Mr.Stephen-K
Hi @Mr.Stephen-K .
I tried a few.
I found some things that were wrong and will tell you about them.
# parent_part_occ.activate = True
parent_part_occ.activate()
# parent_part_occ.activate = False
design.activateRootComponent()
However, it was not the cause of this phenomenon.
I made the following changes to try it out.
            # new_occ = parent_part_occ.component.occurrences.addNewComponent(transform)
            new_occ = root.occurrences.addNewComponent(transform)
In this case it did not result in a warning.
For the root component it is not a problem, only for the occurrence component it is a warning.
I think the "rectangularFeature" created by the Add method is a NativeObject because the nativeObject is set to None.
I felt that this was the cause of the problem, but I could not figure out how to make it a Proxy.
                rectangularFeature = rectangularFeature.createForAssemblyContext(new_occ) #<-error
I added this one, but still got an error.
