Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Pyton Script: Check If File Exists In Folder
1 REPLY 1
isocam
128 Views, 1 Reply
Can anybody help?
Is it possible, using a Python script, to check if a file exists in a particular folder?
Please see the attached picture.
For example:
Say I have a file, saved in the "Reference Parts" folder, called 12345
Can I use the search string 12345 to search the folder "Reference Parts" to see if the file exists, or not.
Return True if it exists or False if it does not.
Many thanks in advance!
Darren
1 REPLY 1
BrianEkins
in reply to: isocam
Here's an example that does what you want.
def CheckForDesign():
    try:
        projName = 'Reference Parts'
        designName = '12345'
        if DesignExists(projName, designName):
            ui.messageBox(f'Design {designName} exists in {projName}')
        else:
            ui.messageBox(f'Design {designName} does NOT exist in {projName}')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def DesignExists(projectName: str, designName: str) -> bool:
    app = adsk.core.Application.get()
    proj: adsk.core.DataProject
    for proj in app.data.dataProjects:
        if proj.name == projectName:
            file: adsk.core.DataFile
            for file in proj.rootFolder.dataFiles:
                if file.name == designName:
                    return True
    return False
Brian Ekins
