Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
python script with a mistake that causes Fusion 360 to crash
1 REPLY 1
mojobility
706 Views, 1 Reply
Search for the two lines in the following script commented with the word CRASH.  I expect that better error checking of the API parameters could allow Fusion 360 to report this as an error instead of crashing.  Although Fusion 360 offered a dialog box to report the crash it would only allow a few lines of text for the description and wouldn't accept me pasting in this script and I am too lazy to try and boil this down to the minimal lines of code needed to reproduce this issue.
import adsk.core, adsk.fusion, traceback
def asInches(val):
    return val*2.54
def toInches(val):
    return val/2.54
# global vars
app = adsk.core.Application.get()
ui  = app.userInterface
product = app.activeProduct
design = adsk.fusion.Design.cast(product)
rootComponent = design.rootComponent
rootFeatures = rootComponent.features
identityMatrix = adsk.core.Matrix3D.create()
def dump(obj):
   for attr in dir(obj):
       if hasattr( obj, attr 😞
           print( "obj.%s = %s" % (attr, getattr(obj, attr)))
def printILine3d(line):
    print ("origin:{:f},{:f},{:f} dir:{:f},{:f},{:f}".format(line.origin.x,line.origin.y,line.origin.z,line.direction.x,line.direction.y,line.direction.z))
    return
def Vector(x,y,z):
    return adsk.core.Vector3D.create(x,y,z)
def Point(x,y,z):
    return adsk.core.Point3D.create(x,y,z)
def assign3(left3, right3):
    left3.x = right3.x
    left3.y = right3.y
    left3.z = right3.z
    return
def notZeroVec3D(vector):
    if vector.x!=0.0:
        return True
    if vector.y!=0.0:
        return True
    if vector.z!=0.0:
        return True
    return False
def sqrt(value):
    return value**0.5
sketchLine_component=None
sketchLine_sketch=None
sketchLine_name=None
sketchLine_lines=None
sketchLine_arcs=None
sketchLine_start_point = Point(0.0, 0.0, 0.0)
sketchLine_point0 = Point(0.0, 0.0, 0.0)
sketchLine_point1 = Point(0.0, 0.0, 0.0)
def sketchLineSetName(sketch_name):
    global sketchLine_name
    sketchLine_name = sketch_name
    return
def sketchLineFillet(line0, line1, radius):
    sketchLine_arcs.addFillet(line0, line0.endSketchPoint.geometry, line1, line1.startSketchPoint.geometry, radius)
    return
def sketchLineStart(sketch_name, sketch_component, sketch_plane, sketch_start_point):
    global sketchLine_component
    global sketchLine_sketch
    global sketchLine_lines
    global sketchLine_arcs
    global sketchLine_start_point
    global sketchLine_point0
    global sketchLine_point1
    sketchLine_component = sketch_component
    sketchLine_sketch = sketch_component.sketches.add(sketch_plane)
    sketchLine_sketch.name = "sketch_"+sketch_name
    sketchLine_lines = sketchLine_sketch.sketchCurves.sketchLines
    sketchLine_arcs = sketchLine_sketch.sketchCurves.sketchArcs
    assign3(sketchLine_start_point, sketch_start_point)
    assign3(sketchLine_point1, sketch_start_point)
    return
def sketchLineNext(sketch_point):
    assign3(sketchLine_point0, sketchLine_point1)
    assign3(sketchLine_point1, sketch_point)
    return sketchLine_lines.addByTwoPoints(sketchLine_point0, sketchLine_point1)
def sketchLineClose():
    assign3(sketchLine_point1, sketchLine_start_point)
def sketchLineExtrude(extrude_distance, extrude_material=None):
    profile = sketchLine_sketch.profiles[0]
    extrudes = sketchLine_component.features.extrudeFeatures
    extInput = extrudes.createInput(profile, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
    extInput.setDistanceExtent(False, adsk.core.ValueInput.createByReal(extrude_distance))
    extrude = extrudes.add(extInput)
    extrude.name = "extrude_"+sketchLine_name
    newbody = extrude.bodies.item(0)
    newbody.name = "body_"+sketchLine_name
    if extrude_material!=None:
        newbody.appearance = extrude_material
    return newbody
def sketchLineExtrudeCut(extrude_distance):
    extInput = extrudes.createInput(profile, adsk.fusion.FeatureOperations.CutFeatureOperation)
    extrude.name = "extrude_cut_"+sketchLine_name
    return
def degreesToRadians(degrees):
    radians = degrees * 3.141592653589793 / 180.0
    return radians
def inputDegrees(degrees):
    return adsk.core.ValueInput.createByReal(degreesToRadians(degrees))
def inputValStr(valStr):
    return adsk.core.ValueInput.createByString(valStr)
def run(context):
#    ui = None
    try:
#        i = app.favoriteAppearances.count
#        while i>0:
#            i -= 1
#            print("{} = {}".format(app.favoriteAppearances.item(i).name,app.favoriteAppearances.item(i).id))
        material_oak = app.favoriteAppearances.itemByName("Oak - Semigloss")
        design.fusionUnitsManager.distanceDisplayUnits = adsk.fusion.DistanceUnits.InchDistanceUnits
        seatOccurrence = rootComponent.occurrences.addNewComponent(identityMatrix)
        seatComponent = seatOccurrence.component
        seatComponent.name = "component_seat"
        # design parameters
        seat_thickness = asInches(0.75)
        pocket_thickness = asInches(0.45)
        seat_back_width = asInches(12.0)
        seat_front_width = asInches(14.0)
        front_radius = asInches(1.0)
        back_radius = asInches(0.5)
        seat_depth = asInches(13.0)
        handle_width = asInches(4.5)
        handle_depth = asInches(1.25)
        handle_front_offset = asInches(2.5)
        rib_width = asInches(0.5)
        rib_radius = asInches(0.25)
        perimeter_width = asInches(0.5)
        num_ribs = 3
        # seat profile
        my_point = Point(-seat_back_width*0.5, seat_depth, 0.0)                            # start at left back
        sketchLineStart("seat", seatComponent, seatComponent.xYConstructionPlane, my_point)
        my_point.x = -seat_front_width*0.5; my_point.y = 0; l0 = sketchLineNext(my_point)
        my_point.x *= -1.0; l1 = sketchLineNext(my_point)
        my_point.x = seat_back_width*0.5; my_point.y = seat_depth; l2 = sketchLineNext(my_point)
        l3 = sketchLineClose()
        sketchLineFillet(l0, l1, front_radius)
        sketchLineFillet(l1, l2, front_radius)
        sketchLineFillet(l2, l3, back_radius)
        sketchLineFillet(l3, l0, back_radius)
        body_seat = sketchLineExtrude(-seat_thickness, material_oak)
        pocket_front_width = (seat_front_width - num_ribs*rib_width - 2.0*perimeter_width) / (num_ribs+1)
        pocket_back_width = (seat_back_width - num_ribs*rib_width - 2.0*perimeter_width) / (num_ribs+1)
        pocket_back_x = -seat_back_width*0.5 + perimeter_width
        pocket_back_y = seat_depth - perimeter_width
        pocket_front_x = -seat_front_width*0.5 + perimeter_width
        pocket_front_y = perimeter_width
        # pocket 1
        my_point = Point(pocket_back_x, pocket_back_y, 0.0)                            # start at left back
        sketchLineStart("seat_pocket1", seatComponent, seatComponent.xYConstructionPlane, my_point)
        my_point.x = pocket_front_x; my_point.y = pocket_front_y; sketchLineNext(my_point) # will CRASH below without l0 = sketchLineNext(my_point)
        my_point.x += pocket_front_width; l1 = sketchLineNext(my_point)
        my_point.x = pocket_back_x+pocket_back_width; my_point.y = pocket_back_y; l2 = sketchLineNext(my_point)
        sketchLineFillet(l0, l1, front_radius) # CRASH occurs inside this function when attempting to add a fillet with the stale line reference l0 to the previous sketch
        sketchLineFillet(l1, l2, rib_radius)
        sketchLineFillet(l2, l3, rib_radius)
        sketchLineExtrudeCut(-pocket_thickness)
        # pocket 2
        pocket_back_x += pocket_back_width + rib_width
        pocket_front_x += pocket_front_width + rib_width
        sketchLineStart("seat_pocket2", seatComponent, seatComponent.xYConstructionPlane, my_point)
        my_point.x = pocket_front_x; my_point.y = pocket_front_y; l0 = sketchLineNext(my_point)
        sketchLineFillet(l0, l1, rib_radius)
        sketchLineFillet(l3, l0, rib_radius)
        # pocket 3
        # pocket 4
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Tags (1)
1 REPLY 1
liujac
in reply to: mojobility
Thanks for reporting this issue. I logged a defect in our internal system. We will fix it.
Jack
