Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Python Script - Get Sheet Metal Thickness
1 REPLY 1
isocam
121 Views, 1 Reply
Can anybody help?
I have seen a lot of posts regarding the lack of support for sheet metal API.
Is it now supported?
I need to be able to get the sheet metal thickness, using a Python script and display the thickness, for testing purposes, in a messagebox.
Many thanks in advance!
Darren
1 REPLY 1
john.kirchner
in reply to: isocam
There are some basic Sheet Metal and Flat Pattern features now available through the API, added last year.
Thickness can be grabbed from the SheetMetalRule object. Thickness returns a SheetMetalRuleValue which you would use .expression or .value depending on what you want to display.
The quickest way to grab a SheetMetalRule is through Component.activeSheetMetalRule
So for an easy example of a file using sheet metal in the root component:
app = adsk.core.Application.get()
des = app.activeProduct
root = des.rootComponent
smr = root.activeSheetMetalRule
smr.thickness.expression # e.g. "2.50 mm"
And you can use that expression in a message box.
