Python Script: Find Folders In Root Directory
isocam
isocam
Can anybody help?
I have the following code. in a Fusion 360 Python script:
def ExportBomFile(BomFileName):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
design = adsk.fusion.Design.cast(app.activeProduct)
activeDocumentName = design.parentDocument.dataFile.name
component: adsk.fusion.Component
for idx, component in enumerate(list(design.allComponents)):
ParentFolderName = str(dataFileFullPath(component.parentDesign.parentDocument.dataFile))
FolderName = component.parentDesign.parentDocument.dataFile.parentFolder.name
Can anybody update the above script so that it includes folders that are located in the root directory as well?
Please see the attached picture.
Many thanks in advance!!
Darren
Rushikesh.kadam
@isocam I may have not fully understood the requirement. But, here is a sample script that gets all the folders present under the root project of a file. From the DataProject object of a file, one can get the rootFolder(DataFolder object). This DataFolder has dataFolders property which is a list of all the folders present under it.
import  adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        for folder in design.parentDocument.dataFile.parentProject.rootFolder.dataFolders:
            app.log(folder.name)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
The script considers only one level of folders. You will need to loop to consider subfolders.
Hope it helps,
If my reply was helpful, please click the "Accept as Solution" button. It helps others get the answer quickly! A "Like" is always welcomed
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
