Announcements
Python Script - Adding Item Number To BOM Export
isocam
isocam
Can anybody help?
I have the following Python script.....
def ExportBomFile(BomFileName):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
design = adsk.fusion.Design.cast(app.activeProduct)
component: adsk.fusion.Component
for idx, component in enumerate(list(design.allComponents)):
PartQuantity = "{:>4}".format(len(design.rootComponent.allOccurrencesByComponent(component)))
PartNumber = re.split(' v\d+', component.partNumber)[0]
ItemNumber = ????????
ui.messageBox(ItemNumber, 'Fusion 360', 0, 3)
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Does anybody know how to add the item number to the script as shown in the attached picture?
Many thanks in advance!
Darren
Jorge_Jaramillo
Hi @isocam ,
Give a try to this recursive function:
def ExportBomFile_recursive(BomFileName, component, item_id, PartQuantity):
    try:
        if item_id:
            ui.messageBox(f'{item_id} | {PartQuantity} | {PartNumber}', 'Fusion 360', 0, 3)
        unique_components = []
        sub_components = []
        for occurrence in component.occurrences:
            if occurrence.component and occurrence.component not in unique_components:
                unique_components.append(occurrence.component)
            sub_components.append(occurrence.component)
        grouped_components = [(comp, sub_components.count(comp)) for comp in unique_components]
        idx = 1
        item_id = f'{item_id}{"." if item_id else ""}'
        for (component, quantity) in grouped_components:
            ExportBomFile_recursive(BomFileName, component, f'{item_id}{idx}', quantity)
            idx += 1
    except:
        if ui:
You can start it by calling:
ExportBomFile_recursive('/tmp/bom.txt', des.rootComponent, "", 0)
You must complete the code regarding adding the results to the BOM file.
Hope this help.
Jorge
