Pull Part Data With Mass and Volume Out of Drawings
jrossHXDQZ
Observer
jrossHXDQZ
Observer
Observer
If I have a bunch of folders that each represent a quote that I need to make up for a customer. Each folder has a different part drawing in it. Is there a way to script it so that I can open any new drawings and export the data to a spreadsheet? It would also be incredible if we could get snapshots of the part with the Properties next to it like I have done in the snip below.
I should also note that I've never created a script in Python before.part info.JPG
Thanks.
OceanHydroAU
Yes, possible, but a reasonable amount of work for a proficient programmer to complete.
If you already know how to program - I estimate that it would take you about 2 months to write this and get it working nicely, while learning python and the Fusion360 API all at the same time.
If you're more of a "hacker class" programmer and just want a quick-and-dirty solution for yourself, perhaps 2 weeks would get it done (learning just enough API and Python as needed).
OceanHydroAU
And, a "Plan B" - these guys have done a load of work that's quite close to what you want, so they might be affordable to adjust their stuff to solve your problem: https://forums.autodesk.com/t5/fusion-360-api-and-scripts/new-addin-available-create-3d-interactive-...
brandon4LWSZ
Observer
Observer
I am looking to hack a similar problem, and will post resources here as I find them (or until I give up).
This is a link to the reference documentation sample for getting "physical properties."
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-ce341ee6-4490-11e5-b25b-f8b156d7cd97
