Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Publish closed source Python script
2 REPLIES 2
419 Views, 2 Replies
Hi, I have a small Python AddIn that I want to publish in the app store
Is there any way to publish it without disclosing its source code?
2 REPLIES 2
goyals
I am not completely sure about it but I think compiled python script should be OK.
Shyam Goyal
Sr. Software Dev. Manager
maxim.yudayev3RJDX
You should look into the Entitlement API on the ModTheMachineBlog
https://modthemachine.typepad.com/my_weblog/2015/10/use-entitlement-api-from-fusion.html
FYI, Python is a "public" language compare to, for example, Java as it does not allow to create public/private classes, etc. Thus, a closed sourcecode is practically impossible as the user can open the Command Window from within Fusion360 and using the Documentation, look into the available class/method descriptions as well as to go into the API folder on their PC and see the code itself, much like you can do the same on your computer for the Fusion360 native commands (Extrude, Pattern, etc.)
Technology Administrators
