Progress dialog pops up after hiding it when messageBox is displayed
m0d0
Message 1 of 1
m0d0
i am probably misunderstanding the behavior of the delay argument in ProgressDialog.show() method.
import adsk.core, adsk.fusion, adsk.cam, traceback
from time import sleep
def run(context):
    ui = None
    ITERATIONS = 10
    TIME_PER_ITERATION = 0.05
    DELAY = 1
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        progressDialog = ui.createProgressDialog()
        progressDialog.show('title','percentage %p\nvalue: %v\nmaximum: %m',0,ITERATIONS,DELAY)
        for i in range(ITERATIONS):
            if progressDialog.wasCancelled:
                    break
            progressDialog.progressValue = i+1
            sleep(TIME_PER_ITERATION)
        progressDialog.hide()
        ui.messageBox('End')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
 As far as i understood the description, the progress dialog shouldn't appear at all if TIME_PER_ITERATION  * ITERATIONS < DELAY. The progress dialog doesn't appear if you are not displaying a message box after the progress. But if you are using the message box the progress dialog pops up at the moment the message box is displayed. Is this the exspected behavior? Is there a way to  'permanently' hide the progress dialog?
I am thankful for any ideas!
Replies (0)
