Programmatically Change Material Properties in Process Material Library
jon6CUA5
jon6CUA5
I know I can modify basic properties like Density, etc. by retrieving the material from app.materialProperties, but these material objects do not seem to have nesting properties like Length, Width, Frame width, Item separation. Is there another way to access those properties?
sophiadoan
@jon6CUA5
I don't have a solution for you. It is not obvious for me from the Fusion API how to get properties. So, how do you access various properties from materialProperties and appearanceProperties. The only property I know how to get is appearanceProperties.itemByName('Image'). Are all property names in the from Fusion material dialog as seen by the user? For example, I got the "Image" name from the "Material Editor" dialog. If so, how would one handle names that appear in sub dialog? I hope all prop names are in a flat data structure.
kandennti
Hi @jon6CUA5 .
We have created a sample that dumps the materialProperties of a selected body.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        root: adsk.fusion.Component = des.rootComponent
        msg: str = 'Select'
        selFilter: str = 'Bodies'
        sel: adsk.core.Selection = selectEnt(msg, selFilter)
        if not sel:
            return
        body: adsk.fusion.BRepBody = sel.entity
        material: adsk.core.Material = body.material
        dump(f'-- {material.name} : {material.id} --')
        props: adsk.core.Properties = material.materialProperties
        dump('(Property.name : Property.id : Property.value : Property.isReadOnly)')
        for idx in range(props.count):
            prop: adsk.core.Property = props.item(idx)
            dump(f'{prop.name} : {prop.id} : {prop.value} : {prop.isReadOnly}')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def dump(s):
    adsk.core.Application.get().log(f'{s}')
    print(s)
def selectEnt(
        msg: str,
        filterStr: str) -> adsk.core.Selection:
    try:
        ui: adsk.core.UserInterface = app.userInterface
        sel = ui.selectEntity(msg, filterStr)
        return sel
    except:
        return None
It seems that each material has different properties that it owns, so I felt that I had to provide an itemById method and an itemByName method.
