I wrote my own tools for this.
Use the Stopwatch for basic timing of "one big thing"
Use the SegmentedStopwatch for tracking the total time spent doing something - or many somethings - (that something may be split over multiple slices - like what was the total time used by this function i called 100 times)
Use RelayStopwatch to get very granular timings - e.g. i want to see how long each and every of those 100 calls to that function took.
Obviously you need to "instrument" your own code to profile it with these timers but it does the job for me 😉
timers.py
# -*- coding: utf-8 -*-
# Author-Ross Korsky
# Timers for profiling performance, etc.
import time
from collections import OrderedDict
__all__ = ['Stopwatch', 'RelayStopwatch', 'SegmentedStopwatch']
class Stopwatch(object):
"""Provides basic stopwatch functionality to time the duration between events.
May be paused and resumed (with another call to run).
def __init__(self, time_fn=time.process_time):
time.process_time - The sum of the system and user CPU time of the current process.
time.perf_counter - A clock with the highest available resolution to measure a short duration.
It does include time elapsed during thread sleep and is system-wide.
self._elapsed = 0
self._started = -1
self._time_fn = time_fn
@property
def elapsed(self):
return self._elapsed
def reset(self):
self.elapsed = 0
self._started = -1
def run(self):
self._started = self._time_fn()
def pause(self):
now = self._time_fn()
if self._started > 0:
self._elapsed += now - self._started
self._started = -1
class RelayStopwatch(object):
"""Allows the timing of each part of a chain of events.
Each section is unique even if the same section name is used multiple times.
def __init__(self, time_fn=time.perf_counter):
It does include time elapsed during sleep and is system-wide.
self.sections = []
self.__active_section_start = -1
def start_section(self, section_name):
if self.__active_section_start > 0:
self.sections.append((self.__active_section_name, now - self.__active_section_start))
self.__active_section_name = section_name
self.__active_section_start = self._time_fn()
def stop(self):
def __str__(self):
s = ''
for name, elapsed in self.sections:
s += '{}: {}\n'.format(name, elapsed)
return s
class SegmentedStopwatch(object):
"""Provides a simple container to maintin several named Stopwatch object."""
self._segments = OrderedDict()
self._active_counts = dict()
self._active_stopwatch = None
def switch_segment(self, segment_name):
if self._active_stopwatch:
self._active_stopwatch.pause()
if segment_name not in self._segments:
self._segments[segment_name] = Stopwatch(self._time_fn)
self._active_counts[segment_name] = 0
self._active_stopwatch = self._segments[segment_name]
self._active_counts[segment_name] += 1
self._active_stopwatch.run()
def pause(self):
"""Pauses the current segment stopwatch."""
def resume(self):
"""Resumes the current segment stopwatch."""
def stop(self):
"""Stops the current segment stopwatch, switch_segment must be called to resume."""
def __str__(self):
s = ''
total = 0
for name, stopwatch in self._segments.items():
s += '{}: {} // {}\n'.format(name, stopwatch.elapsed, self._active_counts[name])
total += stopwatch.elapsed
s += 'TOTAL ELAPSED: {}\n'.format(total)
return s
