Problem writing script code
gpq
gpq
I have a strange situation.
When editing script i write ( like in the sample ) lin1.   , i cannot see all the line's object properties.
I make some mistake but don't understand where.
Thanks in advance.
try:
                curveSel = ui.selectEntity("Select first Line to trim ", "SketchCurves")
            except:
                break
            if curveSel:
                curve = adsk.fusion.SketchCurve.cast(curveSel.entity)
                if type(curve) is adsk.fusion.SketchLine:
                    lin1= adsk.fusion.SketchLine.cast(curve)
                    lin1.geo........       <-------------------------------------------------------------------------( here not propose all propeties of object line )
                    lin1_3D =lin1.geometry.asInfiniteLine()
                else:
                    return
            else:
                return None
marshaltu
I gave a quick check in my machine. It seemed to work well. It would be good if you can share more information as below:
1. Which versions of OS and Fusion 360?
2. Is it reproducible if you restart Fusion 360 and Spyder?
3. Is it specific to some script? If yes, please share the script.
Marshal
Marshal Tu
Fusion Developer
gpq
I cannot see the properties that you can see.
createin assembly context
ednsketchpoint
geometry
startsketcpoint....
Look at mine image.
gpq
Sorry,
The problem is always present in any script and also if I restart fusion and spider. spider is 2.3.2
marshaltu
It was strange. Please try to do clean uninstall/reinstall Fusion 360 and see if it can solve the issue or not?
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
Marshal
Marshal Tu
Fusion Developer
