Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
problem with property: referencedEntity() on SketchCurves
4 REPLIES 4
953 Views, 4 Replies
sorry, typo in title => correction: SketchCurve->referencedEntity() Property
C++ script (please select sketch "Sketch with projections") and sample *.f3d files attached
referencedEntity() problem with projected sketch-curve if source was BRepFaces
no problem with projected sketch-curve if source was BRepEdges
file: example "referencedEntity problem-projection of edges-ok.f3d"
user projected geometry into sketch by selecting edges of occurrences
=> no problem with script
file: "example referencedEntity problem-projection of faces-problem.f3d"
user projected geometry into sketch by selecting faces of occurrences
=> error
=> known limitation?
4 REPLIES 4
goyals
Thank you for reporting it and also sharing with us reproducible steps which saves time to reproduce it on our side. We will fix it soon.
Shyam Goyal
Sr. Software Dev. Manager
goyals
in reply to: goyals
Problem is fixed on our side and fix would be available in Dec. update of Fusion. Thanks for sharing your feedback.
Shyam Goyal
in reply to: goyals
Thank you for your quick response and action!
in reply to: goyals
Great Smiley Happy, fixed with Fusion 360 release 2.0.5044!
Thanks again @goyals !
PS and it is not even december!
